By buying this product you get 299 loyalty points
Questyle's CMA 18 Master DAC/headphone amplifier is a high-performance device featuring top-of-the-range components. It incorporates an ES9039PRO DAC chip and an XMOS XU-316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Added to this is Bluetooth functionality for reception of high-definition codecs such as aptX HD and LDAC, as well as Questyle's patented current mode amplification technology. This amplification technology enables it to reach up to 2W into 32 ohms on its balanced headphone output, and a preamplified line output level that can be boosted with the use of studio mode. The CMA 18 Master offers a complete connectivity with digital/optical inputs, an RCA input, headphone outputs and RCA and XLR line outputs.
The Questyle CMA 18 Master, with its ES9039PRO DAC chip and XMOS XU-316 USB interface, supports sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. The ES9039Pro DAC is a 32-bit, 8-channel chip featuring a Hyperstream IV DAC architecture specially designed for professional audio applications.
The Questyle CMA 18 Master benefits from the brand's patented current-mode amplification technology using discrete components. The headphone amplification and preamplification circuits are independent to ensure high performance and low distortion. The headphone amplifier circuit benefits from a fully balanced architecture, coupled with ALS analog potentiometers for optimum sound reproduction that will get the best out of your headphones. All components are incorporated on a military-grade PCB for optimum heat dissipation.
The Questyle CMA 18 Master supports high-definition Bluetooth codecs like aptX, aptX HD and LDAC for an excellent audio quality, even wireless.
The power supply for the digital circuit and the amplifier/converter circuit is independent, for optimized signal processing. An independent NORATEL toroidal transformer and Schottky rectifier provide the cleanest power supply for the analog side of the DAC.
| 1 | ON/OFF Button |
| 2 | Indicator LEDs |
| 3 | Source selector |
| 4 | DAC / HP AMP operating mode |
| 5 | Gain control Standard / High |
| 6 | Balanced 4.4mm headphone output |
| 7 | 6.35mm jack headphone output |
| 8 | Balanced XLR 4-pin headphone output |
| 9 | Volume control |
| 10 | USB-B input |
| 11 | Toslink optical input |
| 12 | USB-C input |
| 13 | SPDIF coaxial input |
| 14 | Stereo RCA input |
| 15 | Line output gain Standard / Studio mode |
| 16 | Line output selector Fixed / ADJ (volume control) |
| 17 | Stereo RCA line output |
| 18 | Balanced XLR stereo line output |
| 19 | Bluetooth pairing button |
| 20 | AC 110/220V power selector switch |
| 21 | IEC power supply |
| Specifications | |
| Product type | DAC Headphone amplifier |
| Dadc chip | ES9039PRO |
| Amplification technology | Current-mode amplification (CMA) |
| Inputs | 1x USB-C 1x USB-A 1x Optical Toslink 1x Optical coaxial 1x RCA stereo Bluetooth |
| Outputs | 1x Balanced 4.4mm jack headphone output 1x 6.35mm jack headphone output 1x Balanced XLR 4-pin headphone output 1x RCA line output 1x Balanced XLR line output |
| Supported sample rates | USB : PCM up to 32bit 768kHz, DSD DoP up to DoP256, Native DSD up to DSD512 Optical Toslink / SPDIF Coaxial : PCM up to 24bit 192kHz |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC (24bit 96kHz / 990kbps) |
| Headphone output gain adjustment | |
| Preamp output volume control | |
| Compatibility | Win XP/Vista/7/8/10/11, Linux, Android, HarmonyOS, macOS, iOS |
| HEADPHONE AMPLIFIER SPECIFICATIONS | |
| Max. output power | 6.35mm jack: 188mW @ 300 ohm / 1.5W @ 32 ohm Balanced headphone outputs: 765mW @ 300 ohm / 2W @ 32 ohm |
| THD+N | < 0.0003% |
| Frequency response | +/-0.2dB (DC-22kHz) @ 24bit 48kHz |
| SNR | 6.35mm jack: 117dB Balanced headphone outputs: >120dB |
| PREAMPLIFIER SPECIFICATIONS | |
| Max. output level | RCA : 2V (Standard) / +14dBu (Studio mode) XLR : 4V (Standard) / +20dBu (Studio mode) |
| THD+N | < 0.0003% |
| SNR | RCA : >116dB XLR : >119dB |
| General | |
| Power supply | AC 110-240V (selector switch available on rear of unit) |
| Color | Black |
| Weight | 3.5kg |
| Dimensions | 330 x 220.2 x 56mm |
| Package | 1x Questyle CMA 18 Master 1x USB-C to USB-C cable 1x Remote control 1x Power supply cable |
| Input | RCA |
| Input | Optical |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Output | XLR |
| Output | Jack 4.4mm |
| Output | RCA |
| Output | Jack 6.35mm |
| DAC / ADC Chip | ES9039MPro / ES9039MSPro |
| Color | Black |
| Class | N/A |
| Networking | No |
| Remote Control | Yes |
