QULOOS MELOKIN DA9.1 DAC ES9038PRO 32bit / 384kHz DSD512 I2S
With its Melokin DA9.1 DAC, Quloos offers an excellent DAC with high-quality components, including an ES9038PRO converter, two I2S inputs and the ability to add the AMANERO USB module.
KEY POINTS:
  • ES9038PRO
  • 32bit 384kHz - DSD512
  • I2S RJ45 and HDMI
  • USB AMANERO in option
4.0 / 5
By buying this product you get 40 loyalty points
Reference : 12560
409,00 €tax incl.
340,83 € tax excl.
- MELOKIN DA9.1 -
DAC 32bits 384kHz & DSD 512
DAC Quloos DA9.1 MELOKIN
A system with DAC ES9038PRO without compromise
Featuring a design based on the ESS SABRE ES9038PRO converter, the Melokin DA9.1 Quloos DAC does not compromise on excellent audio performance. Thus, this high end DAC is capable of supporting resolutions up to 32bits 384kHz in PCM (with optional AMANERO USB input or I2S inputs), but also supports sampling rates up to DSD512.
Module USB AMANERO Combo 384 in option
The Melokin DA9.1 has a USB slot on the back of the Melokin DA9.1 for an AMANERO Combo 384 USB card, just plug it in and enjoy. This DAC is particularly interesting and powerful thanks to its USB input which allows you to decode the highest sampling rates.
Melokin DA9.1 AMANERO USB
This AMANERO USB module is available as an accessory to this plug.
Drivers for AMANERO available on their website: Drivers Amanero Technologies
Filters for all tastes and desires
The Melokin DA9.1, with its ES9038PRO converter, offers 5 predefined audio parameters to suit all types of listening, but also an "All to DSD"mode. Thus, filters will be found :  short delay, sharp roll-off + short delay, slow roll-off, sharp roll-off + slow roll-off  to avoid phase shift and a filter super slow roll-off. Le mode All to DSd
The output impedance of the headphone amplifier is adjustable
In order to meet all needs, and to match the greatest number of headphones, the output impedance of the headphone amplifier is adjustable.
You can adjust the headphone amplifier output impedance via the front panel buttons. You can set them to: 0 Ohm / 10 Ohm / 120 Ohm.
Quloos DA9.1
High-quality low noise, high quality clock
The Quloos DA9.1 reinvents low-noise power supply with a Jitter-low clock, which ensures vivid natural sound detail and stereo sound field accuracy.
The entire crystal oscillator is directly compatible with CRYSTEK CCHD-575 / CCHD-957 / CCHD-950. It can be replaced directly according to your preferences (Operation to be carried out by a professional - Cancels the product warranty).
Clock DA9.1 Quloos
High-quality connectors
Ensuring complete connectivity, Quloos has chosen to integrate quality connectors into its DA9.1. Coaxial and RCA connectors are silver plated. Most importantly, this device has TWO different I2S inputs: an HDMI and an RJ45. This diversity allows it to adapt to all audio configurations and sources (including I2S network audio players).
Connectique Quloos Melokin DA9.1
Design & Ergonomics
The Quloos DA9.1 boasts a sleek and elegant design that will fit seamlessly into most audio systems. In addition, its design is at the service of sound since it has also been designed to absorb noise and vibration, which could reduce the quality of sound reproduction. Finally, the DAC incorporates many handy LEDs that let you see the source and mode at a glance.
Technical specifications
DACES9038PRO
OPAOPA1622 & OPA1612
Sampling rate supported32bit/384kHz & DSD512 (via USB AMANERO in option and I2S) / 24bit/192kHz & DSD64 DoP (via Coaxial and Optical)
S/N< 125dB
Dynamic range> 125dB
Total harmonic distortion< 0.0003%
Headphone impedance4Ω to 600Ω
Headphone output power250mW 32Ω / 160mW 150Ω / 80mW 300Ω / 40mW 600Ω
Divers
Input voltage required12V / 2A (> 1A)
Dimensions290x265x77mm
Weight0,9kg
OUTPUTS
RCAStereo
Headphone OutputJack 6.35mm
INPUTS
Coaxial2x
Optical1x
I2S1x HDMI / 1x RJ45
USBSlot available
Accessories1x AC adapter 12V 2A, 1x operating instructions manual, 1x remote control
InputI2S via HDMI
InputI2S via RJ45
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rate384kHz
Lest be brief, the Melokin DA9.1 sounds very good, currently tested with an unmodded AKG701, it does have plenty of connection options and the option, if you are so inclined, to add XLR,
The not so good and the reason why it loses one star are some little, but important, annoyances the unit have. To note:
-the input selection are labeled with abbreviatures, instead of the actual names, and those are misprinted in the manual.
- For some baffling reason Quloos opted to use several screw types, Torx, Van Allen, Phillips... makes dissasemly a bit of a PITA
This review has been posted for QULOOS MELOKIN DA9.1 DAC ES9038PRO 32bit / 384kHz DSD512 I2S
With its Melokin DA9.1 DAC, Quloos offers an excellent DAC with high-quality components, including an ES9038PRO converter, two I2S inputs and the...
