SABAJ A10D 2022 DAC 2x ES9038Q2M Headphone Amplifier XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512
10%
The Sabaj A10d 2022 DAC benefits from a digital/analog conversion stage equipped with two ESS ES9038Q2M chips, a high-end DAC supporting high sampling rates and ensuring a rich and precise reproduction. Particularly complete, the A10d is also equipped with a wide range of connectors. It also integrates a headphone amplifier stage with balanced and unbalanced outputs. The DAC also benefits from a Bluetooth 5.0 connectivity, allowing you to transmit your music wirelessly from a smartphone or a tablet.
Reduced price!
Reference : 16494
Limited special offer
299,00 €tax incl.
-10%
269,10 €tax incl.
224,25 € tax excl.
Sabaj A10d 2022
Sabaj A10d 2022 DAC 2x ES9038Q2M Amplificateur Casque XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512
Dual ES9038Q2M DAC
At the heart of the A10d 2022 is a pair of 32bit ESS ES9038Q2M DAC chips, ensuring excellent performance with a dynamic range of 128dB and THD+N of -120dB. This chip also supports high sampling rates, up to PCM 32bit 768kHz and DSD512.
Complete connectivity & Bluetooth 5.0
The A10d 2022 offers a complete connectivity that will allow an easy integration within the vast majority of audio systems. We find in input USB-C, Coaxial, Optical Toslink and Bluetooth 5.0 connectivity. For the outputs, the Sabaj DAC offers unbalanced stereo RCA or balanced stereo XLR as well as two headphone outputs, unbalanced Jack 6.35mm and balanced Jack 4.4mm.
The Sabaj A10d 2022 integrates a Bluetooth 5.0 receiver from Qualcomm, allowing you to broadcast your music remotely, from a smartphone for example. The embedded receiver chip also supports the aptX, aptX HD and LDAC transmission codecs, ensuring excellent sound quality and transmission stability.
DPLL function
DPLL is used to eliminate clock jitter. The DPLL value defines the bandwidth of the clock lock. The wider the bandwidth, the easier the locking. The narrower the bandwidth, the more effective the jitter removal.
Some sources (like some TVs for example) have a too high clock jitter, which can cause an inability of the PLL chip to perform its locking, resulting in a jerky sound. Increasing the DPLL can then correct this problem.
XMOS USB Interface
A second generation XMOS XU208 8-core USB interface accompanies the DAC chip. This one offers an important processing power and allows to support high sampling rates.
Sabaj A20d 2022 DAC ES9038Pro Amplificateur Casque TPA6120A2 XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
1Display
2Multi-function button
3Single-ended Jack 6.35mm headphone output
4Balanced Jack 4.4mm headphone output
5Balanced XLR output
6Single-ended RCA output
7Coaxial input
8Optical Toslink input
9USB-C input
10Bluetooth antenna
11Power connector
Test du Sabaj A10d 2022 par Audio Science Review (Amir)
" Kudos to Sabaj for a job well done across so many areas from design to performance. Yes, there is a bit of room left for products even higher in performance but that gap is incredibly small while cost savings are significant. "
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
1x Balanced stereo XLR
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
DAC chip2x ESS ES9038Q2M
USB InterfaceXMOS XU208
Output levelRCA : 2Vrms
XLR : 4Vrms
Headphone output power2x 2W @ 16Ω
2x 1W @ 32Ω
Headphone output gainLow: 0dB
High: +10dB
THD+NHeadphone output: 0.00012% (-118dB)
DAC: 0.00008% (-121dB)
Dynamic rangeHeadphone output: 121dB
RCA: 124dB
XLR: 126dB
SNRHeadphone output: 121dB
RCA: 124dB
XLR: 126dB
Output impedanceHeadphone output: near 0Ω
DAC : 100Ω
Bluetooth version5.0
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
USB TransmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 10 / 11
Mac OS X 10.6 and later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DoP64
Dimensions200 x 170 x 60mm
Weight1.26kg
ColorSilver
Consumption< 20W
Sabaj A10d 2022 DAC 2x ES9038Q2M Amplificateur Casque XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512 Sabaj A10d 2022 DAC 2x ES9038Q2M Amplificateur Casque XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512
OutputJack 4.4mm
OutputJack 6.35mm
ColorSilver
Remote ControlYes
Très bon Dac
Il remplace un Sanskrit 10th Mk1. Je lui trouve une scène spatiale beaucoup plus étendue et davantage de fidélité aux instruments. Je suis très satisfait de cet achat. Le seul regret c’est l’absence d’un interrupteur marche arrêt car il chauffe toujours un peu.
This review has been posted for SABAJ A10D 2022 DAC 2x ES9038Q2M Headphone Amplifier XMOS XU208 Bluetooth 5.0 32bit 768kHz DSD512
The Sabaj A10d 2022 DAC benefits from a digital/analog conversion stage equipped with two ESS ES9038Q2M chips, a high-end DAC supporting high...
