SHANLING EH2 DAC Headphone Amplifier Silver
With the EH2, Shanling presents a desktop DAC and headphone amplifier that's intended to be the successor to the Shanling HE1. This evolution incorporates digital/analog conversion via an R2R ladder resistor network developed directly in-house by the brand, in order to approach the sound rendering of the PCM1704 chip. As a result, this DAC can process signals up to PCM 32bit 768kHz and DSD512. The amplification stage is based on transistors and offers an output power of 4.32W at 32Ω.
By buying this product you get 36 loyalty points
Reference : 20249
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 28-05-2025.
Shanling EH2 DAC R2R 32bit 768kHz DSD512 Headphone Amplifier Transistors Bluetooth 5.2 Silver
Shanling EH2 : 3/4 view
Shanling EH2: R2R DAC
For its EH2, Shanling decided to develop its own custom DAC. The R2R 24bit DAC takes its inspiration from the legendary PCM1704 DAC chip, enabling digital-to-analog conversion of signals up to PCM 32bit 768kHz and DSD512, while offering sound reproduction with a characteristic analog tone. Furthermore, a NOS mode is also available, allowing you to enjoy your tracks as close to the original as possible.
Shanling EH2 : R2R DAC
Shanling EH2: Transistor amplification
The HE02's amplifier stage relies on BD139 and BD140 transistors for an output power of 4.32W into 32Ω for the balanced headphone output and 1.28W into 32Ω for the Single-ended headphone output. Furthermore, the line output is also equipped with an OPA 1612 to provide an output level of 4.5V balanced and 2.2V single-ended.
Shanling EH2 : Connectors view
Shanling EH2: Extended connectivity
The EH2 also offers more extensive connectivity than its predecessor. It features a Toslink optical input, a coaxial input and a USB-C input. The latter is equipped with an XMOS XU316 interface that supports signals up to PCM 32bit 768kHz and DSD512. Furthermore, the EH2 features Bluetooth 5.2 connectivity thanks to Qualcomm's QCC5125 chip, allowing you to connect wirelessly while maintaining excellent quality thanks to support for LDAC, aptX, aptX HD and aptX Adaptive high-definition codecs.
Product typeDAC
Headphone amplifier
DACR2R 24bit
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
AmplificationBD139
BD140
AOP 1612
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.2
Outputs1x Balanced headphone output 4.4mm jack
1x Single-ended headphone output 6.35mm jack
1x Balanced line output 4.4mm jack
1x Single-ended line output RCA
USB interfaceXMOS XU316
Bluetooth chipQualcomm QCC5125
Supported Bluetooth codecsSBC
AAC
aptX
aptX Low Latency
aptX HD
aptX Adaptative
LDAC
Headphone outputs
Output power 4.4mm JackLow gain: 2365mW @ 32Ω
High gain: 4351mW @ 32Ω
Output power 6.35mm JackLow gain: 632mW @ 32Ω
Hight gain: 1280mW @ 32Ω
Frequency response20Hz-40kHz (-0.5dB)
Total harmonic distotion more noise (THD+N)0.02%
Channel separation111dB @ 32Ω
Dynamic range118dB @ 32Ω
Signal-to-noise ratio (SNR)118dB @ 32Ω
Output impedance<2Ω
Line outputs
Output levelRCA: 2.2V
Jack 4.4mm: 4.5V
Signal-to-noise ratio (SNR)119dB
Supply voltage12V
ColorSilver
Dimensions156 x 150 x 36.5mm
Weight715g
Package1x Shanling EH2
1x Power adapter
1x USB-A to USB-C cable
1x Bluetooth antenna
1x Jack 3.5mm to Jack 6.35mm adapter
OutputJack 4.4mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
ClassN/A
SHANLING EH2 DAC R2R Headphone Amplifier Transistors Bluetooth 5.2 32bit 768kHz DSD512 Silver
With the EH2, Shanling presents a desktop DAC and headphone amplifier that's intended to be the successor to the Shanling HE1. This evolution...
