SMSL D1SE2 Balanced DAC ES9039MSPro CPLD Altera XMOS XU316 32bit 768kHz DSD512 MQA
SMSL's D1se2 represents the direct evolution of the powerful D1se DAC in an updated version, notably with an ESS ES9039MSPro digital/analog conversion chip, flagship of the manufacturer, as well as an XMOS XU316 USB interface. For the rest, the D1se2 takes up the excellent balanced architecture and the careful design of its predecessor, thus providing a clear, precise and incredibly transparent sound reproduction.
By buying this product you get 89 loyalty points
Reference : 17428
899,00 €tax incl.
749,17 € tax excl.
Shipping date: 03-06-2025.
SMSL D1se2
SMSL D1SE2 DAC ES9039MSPRO Symétrique CPLD Altera XMOS XU316 32bit 768kHz DSD512 MQA
MQA / MQA-CD Support
The SMSL D1se2 is able to decode MQA (Master Quality Authenticated) audio files. These are the guarantee of a restitution quality as close as possible to the original recording in studio for an incomparable listening. It also allows the reading, via an adapted CD player, of the MQA-CD format.
ES9039MSPro DAC & High-end components
The D1se2 uses the new ESS ES9039MSPro DAC chip for its digital/analog conversion stage, a high-end model from the manufacturer, ensuring excellent sound performance. In addition, this 32bit 8-channel chip ensures very low distortion and supports high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
The D1se2's circuitry also benefits from high-end components. There is a perfectly managed power supply stage, embedding a NORATEL toroidal transformer and Nichicon KG filtering capacitors, providing the DAC with a low noise electrical signal. A 32bit XMOS XU316 USB interface is also used to process USB streams quickly and efficiently. In addition, the CK-03 clock circuit ensures low jitter.
Bluetooth reception
The SMSL D1se2 embeds a Bluetooth 5.0 receiver and an antenna, allowing you to remotely broadcast your music, directly from your smartphone. Moreover, it supports the aptX, aptX HD and LDAC codecs, ensuring a fast and stable transmission for a quality of restitution close to that of the CD.
1Screen
2IR Receiver
3Input selection button
4Bluetooth button
5Standby LED indicator
6Multifunction button
7Single-ended RCA line output
8Bluetooth antenna
9Optical input
10Balanced XLR line output
11I2S input
12Coaxial input
13USB input
14Power input (100-240VAC)
VMV D1se2 review by AudioScienceReview (Amir)
" I expect state of the art performance in DACs from SMSL and hence VMV and that is what we get in D1se. I am happy to recommend the VMV D1se2 stereo DAC. "
https://www.audiosciencereview.com/forum/index.php?threads/vmv-d1se2-stereo-dac-review.45052/
Product typeDAC
DAC chipESS ES9039MSPro
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x I2S via HDMI
Bluetooth
Outputs1x Single-ended RCA
1x Balanced XLR
THD+N0.00005% (-125dB)(No-weighted)
Dynamic rangeXLR : 133dB
RCA : 128dB
SNRXLR : 133dB
RCA : 127dB
Line out amplitudeXLR : 5.2Vrms
RCA : 2.5Vrms
USB transmissionAsynchronous
USB compatibilitéWindows 7 / 8 / 8.1 / 10
Mac OSX
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512, MQA
Optical / Coaxial : PCM up to 24bit 192kHz, DSD64 (DoP), MQA, MQA-CD
Bluetooth version5.0
Bluetooth codecsAAC, SBC, aptX, aptX HD, LDAC
Consumption< 10W
Standby consumption< 0.5W
Housing materialAluminum
Dimensions210*170*39mm
Weight1.63kg
Package1x D1SE2 Noir
1x Bluetooth antenna
1x Remote control
1x Power cable
InputI2S via HDMI
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
Excellent!
This is one fantastic dac! Compared to Smsl D300 this D1se2 is more detailed and sound more technical without getting harsh. And this is right out of the box! Its smooth and will probably get better with a little more time! Big soundstage and very good control off the lowest frequency! Was a little worried it would be to bright for me, but thats not an issue. Good layering within soundstage, not flat like Topping d90se.. Its a keeper! Using this with Audiolab 6000a and Wharfedale evo 4.2. This is my first purchase from Audiophonics. No problems, very fast shipping to Norway!!
 (7)
This review has been posted for SMSL D1SE2 Balanced DAC ES9039MSPro CPLD Altera XMOS XU316 32bit 768kHz DSD512 MQA
SMSL's D1se2 represents the direct evolution of the powerful D1se DAC in an updated version, notably with an ESS ES9039MSPro digital/analog...
