SONCOZ LA-QXD1 DAC Balanced ES9038Q2M 32bit 768kHz / DSD512 XMOS Silver
SONCOZ LA-QXD1 DAC Balanced Double ES9038Q2M 32-bit 768kHz / DSD512 XMOS Black
By buying this product you get 22 loyalty points
Reference : 14528
229,00 €tax incl.
190,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
SONCOZ LA-QXD1
ES9038Q2M 32bit / 768kHz DSD512
Review by Audio Science Review
Usually balanced output comes at a cost of higher price as it is considered a premium feature. Not the case here. You get XLR output and importantly, with superbly low noise and distortion for a really budget price.
 test by the measurement forum Audio Science Review
Very complete balanced digital / analog / DAC interface integrating dual SABRE ES9038Q2M chips and USB XMOS interface.
Its resolutely high-end circuit, its simple and compact construction as well as its very accessible interface make it an ideal solution for audiophiles looking for an easy-to-configure DAC for any high-fidelity installation.
ES9038Q2M DAC chip
The LA-QXD is a well designed DAC built on two chips ES9038Q2M Sabre 32-bit integrated in balanced mode.
This component belongs to ESS flagship series and is among the best current hardware solutions for high-fidelity audio decoding. It uses HyperStream 32 BIT 768kHz architecture with native DSD support. Each one of this chips is also equipped with advanced reconstruction filters and uses some of the finest dithering techniques available on the audio market.
ESS ES9038Q2M SABRE DACs are also very popular thanks to their ability to operate volume with almost no consequences on the audio bitrate.
USB interface & S/PDIF interface
The LA QXD1 has a USB input on a USB-B connector controlled by a XMOS U208 interface. The latter allows it to work directly from audio streams on your computer or any device with this type of connector.
A second separate USB connector is in charge of powering the device. This redundancy makes it possible to completely ignore the audio parasites induced by a non-isolated USB source. This power connector is USB-C to facilitate scenarios of nomadic use and battery power.
In addition to the USB input, the LA QXD1 has an S / PDIF interface. The latter allows it in the first place to decode the S / PDIF streams received on its oaxial & optical inputs with a 24-bit / 192kHz / DSD64 resolution.
In addition, the SPDIF interface is also connected to the USB interface as well as to a digital output on coaxial port. In addition to its DAC function, the LA-QXD1 can thus work as a digital interface able to interface its optical / coaxial and USB inputs to an S / PDIF coaxial output.This digital interface output offers various integration possibilities for occasionally or permanently connecting devices that do not have the appropriate inputs/outputs.
Simple and accessible control panel
The device is easily controlled using four buttons located on the front panel. These provide access to source selection, digital filter adjustment, volume control and mute functions.
A panel of four LEDs indicates the active output in real time and allows you to check that the device is powered up.
TypeDAC
Digital interface
ArchitectureBalanced
chip DACES9038Q2M
InputsUSB-B (XMOS)
Optical Toslink
Coaxial SPDIF
OutputsAnalog stereo RCA (single-ended)
Analog stereo XLR (balanced)
Digital Coaxial SPDIF
Sampling frequencyUSB: 32-bit / 768kHz PCM - DSD512 (native)
Optical 24-bit / 192 kHz PCM - DSD64
Coaxial: 24-bit / 192 kHz PCM - DSD64
Output LevelXLR: @ 4.0Vrms 0dBFS
CAR: @ ??2.0Vrms 0dBFS
Frequency response20Hz ~ 20KHz (± 0.18dB) XLR / RCA
Dynamic range> 124dB A-Weighted
THD + N<0.00015% @ 1kHz XLR / RCA
Crosstalk> 130dB @ 1kHz XLR / RCA
Output impedance200Ω XLR
100Ω RCA
Noise floor modulation
<4.3μVrms
Dimensions149.3 x 87 x 37mm
Weight475g
Package contents
LA-QXD1x1
USB-B male / male USB-A Cablex1
USB-C male / male USB-A Cablex1
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Download
3 reviews
Superbe
Tres bon appareil, rapport q/p assez imbattable, le petit tient la dragee haute au Fostex HPA8, c'est dire... Sans toutes les possibilites du second bien sur, mais il est tres difficile, voire impossible de faire la difference entre les 2. Une bonne alim iFi est semble t il conseillee pour ameliorer encore la performance du jouet, a voir. Belle transparence, scene realiste, timbres tres realistes egalement, les Geithain sont au top de la forme depuis 15 jours. 5 etoiles donc, avec un petit moins pour l 'absence de mode d'emploi. Un plus encore pour la fabuleuse dynamique, les amateurs de classique aprecieront. Et merci comme toujours a APhonics pour le service, 4 jours jusqu'au fin fond de la Germanie en temps de corona, un record.
This review has been posted for SONCOZ LA-QXD1 DAC Balanced ES9038Q2M 32bit 768kHz / DSD512 XMOS Silver
excellent!
Read this and I can only concur.
https://www.headphonesty.com/2020/07/review-soncoz-la-qxd1-dac/
mauvaise pioche
L'appareil que j'ai reçu faisait des pauses pendant l'écoute, environ 1 toutes les minutes.
Je l'avais connecté comme cela: entrée sur RCA coaxial sortie sur RCA.
A noter qu'il n'y a pas de télécommande.
Audiophonics a été correct et me l'a repris.
