Utilisé avec Mpd et Rapberry Pi OS sur un Raspberry 4 sans aucun problème.
Le Dac est reconnu out of the box.
USB DAC 24bit/96kHz - SA9023 / ES9023
A USB-B cable (not-included) is required for input signal.
The Audiophonics DAC U-SABRE LTE is equipped with a modern USB Audio input interface. The decoding chip is ESS's famous ES9023 Sabre, known for its ease of use and efficiency. Thanks to this small device, you can enjoy high fidelity sound quality at a lower price, up to 24 bit / 96kHz.
The DAC's RCA analog output allows it to be paired with a stereo amplifier, or even a dedicated headphone amplifier. In short, you are in the company of a USB DAC with high quality features in a compact format.
The Audiophonics U-Sabre LTE DAC is self-supplied USB powered by any laptop or computer. This makes it a simple and functional Plug & Play digital interface.
You will enjoy dematerialized sources without sacrificing your current HiFi installation, by connecting it to your stereo amplifier for example. The musicality of the ES9023 will do the job perfectly.
This Bravo SA9023 USB interface is an important part of our U-Sabre LTE, in fact this last one is Asynchronous. In addition, it allows you to accept your music files up to 24 bit / 96kHz, passing of course through the digital signals 32kHz, 44.1kHz, 48kHz and 88.2kHz. In short, Saviaudio's quality and expertise can be found in this modern USB interface.
This nomadic High Definition DAC is equipped with the famous SABRE ES9023 24-bit / 96kHz, which incorporates Hyperstream technology to overcome the usual faults of the classic Delta Sigma DACs. The result is immediately perceptible, thanks to a feeling and sound precision above the Delta Sigma competitors
Compatibility | Native / Plug & Play on Windows, Linux, OS X |
USB | Asynchronous |
DAC | Sabre ES9023 Asynchronous |
Analog output | Direct Out |
Power supply | 5V DC (Via USB) - No external power supply required |
USB input (SA9023 SAVIAUDIO) | Up to 24bit 96kHz (We recommend the use of qualitative cable with a length of less than 1.5m.) |
Stereo RCA output | Gold plated |
Dimensions | 58 x 69 x 24mm |
Case material | Aluminium |
Color | Black |
Input | USB |
Output | RCA |
DAC / ADC Chip | ES9023 |
Max sampling rate | 96kHz |
Color | Black |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 24 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
eric m.
Jean-Benoit K.
Philippe w.
Serge P.
Gerard G.
