DENAFRIPS PONTUS II 12TH-1 DAC R2R NOS Balanced Silver
The Denafrips Pontus II 12Th-1 NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here, each channel is equipped with an independent high-speed FPGA to facilitate digital signal decoding by means of 4 sets of high-precision R-2R networks.
By buying this product you get 209 loyalty points
Reference : 18901
2 090,00 €tax incl.
1 741,67 € tax excl.
Denafrips Pontus II 12Th-1 DAC R2R NOS Balanced 1536kHz DSD1024 Silver
Denafrips Pontus II 12Th-1 : Vue de face
The Denafrips Pontus II 12Th-1 NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here, each channel is equipped with an independent high-speed FPGA to facilitate digital signal decoding by means of 4 sets of high-precision R-2R networks. The choice of such a design results in very low linearity error, high decoding speed and low digital noise, not only to ensure that the audio signal has very low distortion, but also to ensure very low background noise.
All digital inputs are buffered in FIFO memory and reclocked by integrated femtosecond oscillators. Excellent jitter rejection makes the Denafrips Pontus II 12Th-1 much less dependent on the quality of the source equipment's clock.
Points clés :
  • Proprietary R2R + DSD architecture
  • True balanced 24bit R2R + 6bit DSD (32-step FIR filters)
  • Precision resistors (0.001%)
  • Femtosecond clocks 45.1548MHz, 49.152MHz
  • Ultra-low-noise isolated power supply
  • Support for PCM streams up to 1536kHz and DSD up to DSD1024 (USB and I2S)
  • Proprietary USB interface via STM32F446 MCU
  • Thesycon USB driver
  • Dual AES/EBU input
  • I2S pinout configuration
  • Sharp / Slow filters
  • I2S DSD channel configuration
Denafrips Pontus II 12Th-1: Internal view
Denafrips Pontus II 12Th-1: A customized power stage
The Denafrips Pontus II 12Th-1 features a linear power supply stage specifically developed for this DAC and isolated by a 1.5mm-thick metal case to considerably limit interference.
Placed beneath the DAC board, this power supply circuit embeds two large O-Core transformers for the digital and analog sections, low ESR capacitors and a super-linear linear power supply to provide the conversion stage with a clean, stable electrical signal.
Denafrips Pontus II 12Th-1: Power stage
Denafrips Pontus II 12TH-1: Comprehensive connectivity
The Denafrips Pontus II 12Th-1 features comprehensive connectivity for easy integration into the vast majority of audio systems. Inputs include USB-B, I2S via HDMI, Toslink optical, AES/EBU and coaxial. On the output side, the DAC provides unbalanced RCA and balanced XLR.
Denafrips Pontus II 12Th-1: Connectors
1Balanced XLR output
2Single-ended RCA output
3Coaxial input (RCA)
4cCoaxial input (BNC)
5 / 6AES/EBU input
7Optical input
8I2S input via HDMI
9USB-B input
10Power connector
Product typeBalmanced NOS R2R DAC
Inputs1x USB-B
1x I2S via HDMI
1x Optical Toslink
2x AES/EBU
1x Coaxial BNC
1x Coaxial RCA
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesUSB / I2S : PCM up to 24bit 1536kHz, DSD up to DSD1024
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP64
Output level / impedance2Vrms @ 625 Ohm
4Vrms @ 1250 Ohm
Sampling modesNon-oversampling (NOS)
Oversampling (OS)
Frequency response20Hz - 70kHz (-3dB)
THD+N0.0025%
SNR120dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
Consumption<= 20W
ColorSilver
Dimensions320 x 330 x 80mm
Weight8.5kg
Package1x Denafrips Pontus II 12Th-1 Silver
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
ColorSilver
Étonnant ce Pontus
Il a pris la suite d’un Schiit Yggdrasil de 5 ans à la sonorité qui me convenait mieux que celle des ESS et autres…
J’avais déjà goûté au DAC R2R avec un DAP Hiby RS8 cela m’a décidé .
Le Pontus est sidérant!
J’écoute au casque ( Utopia) avec un ampli à tubes, le Prautes et un lecteur réseau Aries G1. Il n’y a pas de mots pour exprimer mes nouvelles sensations musicales .Essayez, vous verrez …
Je vais changer de lecteur réseau, j’attends avec impatience un Aries S1 qui me promet encore un peu plus de plaisir musical.
Quel bonheur ces nouveaux appareils…
This review has been posted for DENAFRIPS PONTUS II 12TH-1 DAC R2R NOS Balanced 1536kHz DSD1024 Silver
The Denafrips Pontus II 12Th-1 NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering...
