HOLO AUDIO SPRING 3 LEVEL 2 Balanced R2R DAC 32bit 1536kHz DSD1024
Holo Audio unveils with the Spring 3 a beautiful R2R DAC based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge of PCM streams and the other of DSD streams. An impressive design which allows to benefit fully from the capacities of this last format.
By buying this product you get 275 loyalty points
Reference : 15776
2 759,00 €tax incl.
2 299,17 € tax excl.
Shipping date: 16-12-2025.
Garantie 3 mois
Holo Audio Spring 3 Level 2
HoloAudio Spring 3 Level 2 DAC R2R Symétrique 32bit 1536kHz DSD1024
  • New generation of linear compensation technology to correct component resistance and switching problems.
  • The new generation of de-glitch technology provides full bandwidth without increasing background noise.
  • The Spring 3 achieves a SINAD of over 112dB and a dynamic range of >128dB, the best performance an R2R DAC can offer.
  • PLL+FIFO technology for drastically reduced jitter. Use of a high-performance femtosecond VCXO as the source of the PLL clock signal.
  • Proprietary firmware for the USB interface, with ultra-low latency and exceptional reliability.
  • I2S input via HDMI with independent four-channel circuitry, eliminating jitter and interference problems. Configurable I2S input pinout for maximum compatibility.
Level 2 Model
The Level 2 model of this HoloAudio Spring 3 incorporates specially designed capacitors for optimal power filtering for more neutral and detailed sound reproduction. It is also equipped with a Red Label 5N transformer with copper wiring. This version also comes with a CNC-machined remote control.
R2R & DSD
The Spring 3 is one of the few balanced R2R DACs to natively support DSD streams, using directly the discrete components of the D/A conversion stage. It is also compatible with MAC (DoP), Linux (DoP) and Windows (Native and DoP) systems.
R2R Architecture
Today's delta-sigma DACs differ from R2R models, as the former technology goes through an oversampling and high-speed digital switching stage that can cause distortion and sound artifacts. The R2R structure, on the other hand, is much more direct and pure, using a high-precision resistor network that negates the problems associated with delta-sigma conversion. What's more, the HoloAudio Spring 3 is the first discrete DAC with linear compensation, providing extremely accurate sound reproduction.
The input stage of the Spring 3 uses an AOP and its output stage discrete components, the latter operating in Class A.
Incredible sound reproduction
One of the Spring 3's strengths is its ability to deliver a wide soundstage with great precision. High frequencies are particularly detailed, without being aggressive. Bass frequencies are deep and textured, but never mask the midrange.
Linear compensation
The Spring 3 incorporates an additional R2R ladder, allowing compensation of the main R2R ladder. This additional ladder works in a similar way to trimming, but without changing the value of the resistors. It is digitally controlled and effectively compensates the tolerance of the resistors. A method that allows to reach a very high level of accuracy, with an almost perfect linearity, an extremely low THD and a particularly high SNR.
HoloAudio Spring 3 review by AudioScienceReview (WolfX-700)
Test du HoloAudio Spring 3 par AudioScienceReview (WolfX-700)
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typeR2R DAC
Inputs1x USB-B
1x I2S via HDMI
1x Optical Toslink
1x AES/EBU
1x Coaxial (RCA)
1x Coaxial (BNC)
1x Balanced stereo XLR
Supported samplinf ratesUSB : PCM up to 32bit 1536kHz, Native DSD up to DSD1024, DSD DoP up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.00032% @ PCM 48K NOS, 1K (1-110dB)
0.00025% @ DSD128X, 1K (-112dB)
Dynamic range127dB @ PCM 48K NOS
115dB @ DSD128X
DAC Output voltageRCA : 2.9Vrms @ PCM 48K NOS, 1.45Vrms @ DSD128X
XLR : 5.8Vrms @ PCM 48K NOS, 2.9Vrms @ DSD128X
Supply voltage110-240VAC 50/60Hz
Power cableIncluded
Housing materialAluminum
Dimensions430 x 300 x 55mm
Weight8.5kg
Package1x Spring 3 Level 2
1x USB-A to USB-B Cable
1x Aluminum remote control
InputBNC
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
ColorCopper
Remote ControlYes
9 reviews
Petit bijoux
Je juge ce petit bijoux de DAC en association avec le HOLO Biss (voir mon commentaire). Aucune fonctionnalité, aucun réglage, une télécommande qui ne sert presque à rien (sans option préamp puisque qu'il est raccordé au Bliss) et c'est tant mieux finalement. je préciserais vis à vis des commentaires déjà nombreux que cette technologie R2R est vive et rapide sans aucune froideur. Pour dire, j'ai retiré ma platine vinyle avec une Ortofon 2M Black dépassée par ce DAC sur tous les critères. Comme source j'utilise un MacBook Pro avec Audirvana + le VST Dirac. Connection USB robuste et très bonne. La licence Dirac coute cher mais il le mérite, croyez moi.
Période de rodage nécessaire avec un peu de patience ...
This review has been posted for HOLO AUDIO SPRING 3 LEVEL 2 Balanced R2R DAC 32bit 1536kHz DSD1024
Le nivarna
J’ai mis longtemps pour me décider, tellement de choix, les prix. Et à force de lire tous ces retours positifs sur ce dac, j’ai donc passé le cap.
Il a aujourd’hui 150 heures de fonctionnement et c’est une merveille, chaque écoute est une douceur musicale dans le bons sens de terme, une richesse et un respect des timbres, faut il encore avoir les éléments l’entourant qui soient à la hauteur de ce monstre d’efficacité.
Je ne peux que conseiller ce dac .
 (3)
Transparent, détendu et superbement ouvert, à la fois bon en PCM et en DSD
Ce DAC excelle à tous les niveaux, la musique coule naturellement avec la vigueur nécessaire sur les temps forts des enregistrements. La spatialisation est excellente, beaucoup de largeur et de profondeur, les hautes fréquences sont sans dureté et bien étendues, belle restitution des timbres des instruments et voix. J’ai eu un Gustard R26, R2R comme ce Holo, c’est une progression en tous points, la musicalité est plus grande, cela me parait plus précis et hautement transparent, tout en conservant le caractère émotionnel. L’investissement vaut le coup, c’est un DAC qui s’insère parfaitement dans un ensemble haut de gamme, j’apprécie ses performances en termes de restitution sur tous les styles musicaux. J’utilise en coaxial pour la lecture de CD et en USB pour la musique dématérialisée jusqu’aux DSD, satisfait sur les différents formats.
Remerciements à Monsieur Aubert qui m’a permis de le sélectionner par rapport à d’autres options que j’envisageais. Je trouve que ce DAC a un excellent rapport prix qualité sonore vraiment bien, pour quelqu’un qui écoute tous les formats et souhaite écouter ses albums tant en format original que sur des fréquences plus élevées après suréchantillonnage jusqu’aux DSD.
vive le R2R....
Matière, détail, scène sonore,. Le traitement des sifflantes sur les voix, la cohérence entre la réverbération et les instruments acoustiques, (guitare classique par exemple) en prise live, est à mes oreilles très convaincantes. Une écoute réaliste, un vrai plaisir.
 (3)
Une merveille
La vérité, rien que la vérité, je le jure !...
J'ai l'impression d'avoir ouvert une porte sur un autre espace. ce n'est pas seulement le fait de retrouver un son analogique, c'est juste le meilleur de l'analogique et du numérique...
(Et pourtant je n'ai pas encore l'amplificateur qui permet de driver mes casques sensibles)
En plus la qualité de fabrication est absolument sublime, quelle merveille...
Pour info entre la sortie USB (depuis un PC avec iPurifier) et la coaxiale via M2Tech Hiface, la sortie USB est bien meilleure, plus douce et équilibrée.
Des heures d'écoute sans aucune fatigue. Clairement un saut dans un nouveau monde.
Et merci Audiphonics pour le contact et les conseils.
MG
Holo Audio unveils with the Spring 3 a beautiful R2R DAC based on discrete components. Custom designed, it offers incredible performances thanks to...
