Wireless DAC with RF Transmitter 24bit 96kHz
With the NAD DAC2, digital music meets audiophile sound. This simple and highly efficient solution allows you to listen to the music stored on your computer directly on your HiFi system, seamlessly and without the need for a WiFi connection, thanks to its RF transmitter. The wireless point-to-point technology allows for a simple installation to enjoy your audio files up to 24bit 96kHz, without compression.
The NAD DAC2 consists of both a DAC and a USB RF transmitter module, offering a range of up to 40m. The DAC2 is also the possibility to enjoy your favorite streaming services and web radios. To further enhance the experience, many mobile applications will allow you to control your PC or Mac remotely.
The signal received via the USB input of the RF transmitter is directly transmitted wirelessly to the DAC2's digital-to-analog conversion module, which uses high-quality components such as Burr-Brown AOPs, a Delta-Sigma 24/192 DAC and a selection of passive components, all within a proprietary NAD circuit.
| 1 | Transmitter channel selection |
| 2 | Mini USB 2.0 input |
| 3 | Analog output |
| 4 | Digital output |
| 5 | Coaxial output |
| 5 | 5VDC Power supply |
| 6 | Right channel RCA output |
| 7 | Left channel RCA output |
| 8 | DAC Channel selection |
| Specifications | |
| Product type | Wireless DAC |
| Inputs | 1x Mini USB 2.0 |
| Outputs | 1x Stereo RCA 1x Coaxial SPDIF |
| Supported sampling rates | PCM up to 24bit 96kHz |
| THD+N | 0.05% |
| SNR | > -80dB |
| Analog output level | 2V |
| SPDIF Coaxial output level | 500mV ±50mV |
| Frequency response | 20Hz - 48kHz ±0.5dB |
| DAC type | Delta-Sigma |
| Time delay | < 18ms |
| Max transmission distance | 40m (line of sight) |
| General | |
| Dimensions | DAC : 135 x 70 x 35mm Transmitter: 73 x 15 x 35mm |
| Weight | 380g |
| Package | 1x NAD DAC2 and its transmitter 1x Power adapter 1x USB-A to mini-B cable 1x Stereo RCA cable |
| Input | USB |
| Output | RCA |
| Output | Coaxial SPDIF |
| DAC / ADC Chip | NC |
| Max sampling rate | 96kHz |
| Color | Black |
| Networking | Yes |
| Remote Control | N/A |
