SINGXER SDA-1 DAC AK4490 I2S XMOS 32Bit / 384KHz DSD512 DOP
Singxer offers with its SDA-1 a high performance DAC reflected and developed by the brand for more than two years. This is based on a third generation AKM converter, an AK4490. This is accompanied by an excellent USB XMOS Xcore 200 chip, a digital AK4418 interface and a 32bit STM32 microcontroller at the heart of the device to process all the informations.
Reference : 12816
690,00 €tax incl.
575,00 € tax excl.
This model has been replaced by the new Singxer SDA-6 PRO AK4499.
Singxer SDA-1
DAC AKM AK4490 I2S USB XMOS 32bit 384kHz DSD512 DOP
Singxer SDA-1
The AK4490, a powerful and well accompanied DAC
In order to offer an efficient D/A conversion, the SDA-1 is based on an AKM AK4490 DAC. This 32bit converter promises a very low distortion rate and a wide dynamic range for a precise and crisp sound. The chip incorporates a new "OSR Doubler" switched-capacitance filter, enabling it to support many audio signals with very low noise and power consumption. It is thus able to decode files up to 32bit 384kHz via USB and I2S inputs but also native DSD256.
But the AK4490 is also well surrounded since there is a Xilinx FPGA in the device that takes care of the clock system and digital audio signal processing. To lower the jitter of the USB it is no less than 4 independent clocks which intervene. A high-performance hybrid digital-to-analog phase locked loop improves clock synchronization and recovery. In the I2S side is the Xilinx FPGA and the source synchronization technology allows to adjust the isolated signal, eliminating the jitter of the isolation chip.
Complete HiFi-oriented connectivity
The Singxer SDA-1 has a particularly rich and resolutely High Fidelity oriented connectivity. The input includes an XLR connector for AES/EBU, a Coaxial connector and a BNC connector for SPDIF, an HDMI LVDS connector for I2S signals and finally a USB-B connector directly connected to the XMOS Xcore interface. For I2S, the PCM and DSD signals are automatically recognized by the FPGA of the device. In addition, a series of switches under the device allows the different I2S modes to be adapted.
As far as analog outputs are concerned, two choices. One unbalanced output with RCA stereo connectors and one balanced output with XLR 3-pin connectors.
Singxer SDA-1 connectique
Review by Qobuz
Qobuz has tested the Singxer SDA-1 for you. Discover now their test by following this link !
DACAKM AK4490
Sampling ratePCM USB / I2S : Up to 32bit 384kHz
PCM SPDIF : Up to 24bit 192kHz
DSD Native USB /I2S : Up to DSD512
DSD DoP SPDIF / AES/EBU : DSD64
ImpedanceSPDIF : 75Ω
AES/EBU : 110Ω
Output level (0dBFS)PCM RCA single-ended output : 2V RMS
PCM XLR balanced output : 4V RMS
DSD RCA single-ended output : 1.34V RMS
DSD XLR balanced output : 2.68V RMS
Output impedanceSingle-ended RCA : 22Ω
Balanced XLR : 45Ω
Frequency response20Hz - 20kHz ±0.1dB
SNR118dB
DistortionPCM : THD+N (1kHz 0dBFS) 0.00042% @ fs = 44.1kHz
DSD128 : THD+N (1kHz 0dBFS) 0.0003%
Dynamic response (1kHz -60dBFS)118dB
Left / Right channels separation> 120dB
AES/EBU : 110Ω
Find in the "Download" tab of this page the results of measurements and analyses of the SDA-1.
Connectors
Digital inputs1x AES (Female XLR 3 poles)
1x Coaxial SPDIF
1x BNC SPDIF
1x I2S via HDMI LVDS (SU-1 interface compatible)
1x USB-B
Analog outputs1x XLR (Male 3 poles)
1x Stereo RCA
Power supplyIEC C13
CompatibilityWindows 7, 8, 10 (32/64bit) : driver needed
Mac OS 10.6 and later version
Linux with UAC2 compatible kernel
Android 4.2 and later version (OTH device needed)
Dimensions266 x 235 x 58mm
Weight2.6kg
Package1x Singxer SDA-1
1x USB-B to USB-A cable
1x Power supply cable
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
InputBNC
InputXLR
InputI2S via HDMI
DAC / ADC ChipAK4490
Max sampling rateDSD512
Max sampling rate384kHz
Singxer offers with its SDA-1 a high performance DAC reflected and developed by the brand for more than two years. This is based on a third...
