IBASSO DX120 DAP HiFi Music Player DAC AK4495 32bit 384kHz DSD128 Brown
The iBasso DX120 is a high-end digital music player (DAP) that delivers high-flying audio performance thanks to its clever design. DAC AK4495, USB XMOS XU208, Quad Core CPU, dual PLL / TCXO clock and fast charging make this DX120 an ideal companion for your listening sessions at home or on the go.
4.8 / 5
Reference : 13534
299,00 €tax incl.
249,17 € tax excl.
iBasso DX120
iBasso DX120 Baladeur Numérique DAP HiFi DAC AK4495 32bit 384kHz DSD128
AK4495 DAC
A large part of the development of the DX120 was to get the most out of the DAC AK4495 chip. The specifications of this chip display a THD+N at -105dB. In practice, it is quite difficult to achieve such a value. The engineers at iBasso have therefore worked on the design of a unique design, allowing to reach a THD+N of -111dB !
Balanced output
For its amplification section, the DX120 uses one AOP per channel, with a fully symmetrical output scheme. Thus, the output in 2.5mm symmetrical Jack format combined with the careful architecture of the DAP ensure low distortion and crosstalk.
TCXO + PLL Synchronization technology
To ensure an extremely low jitter, the DX120 integrates a combo of PLL and TCXO clocks. The phase noise reaches a value of -145dBc/Hz, the jitter is brought to <=35ps and the frequency stability is less than 1ppm for a sound reproduction of great transparency and precision.
A large power reserve
The internal design of this DAP allows it to be used with a wide range of headsets and IEMs, including demanding models. Indeed, it offers a power of 400mW for a load of 32 Ohm and an impressive restitution of low frequencies.
Carefully selected components
The iBasso DX120 features carefully selected components. Underneath its robust aluminium shell is a DAC AK4495 chip that supports high sampling rates, with PCM up to 32bit 384kHz and native DSD128. This chip is combined with a high-performance USB XMOS XU208 interface, a BQ25890 MaxCharge TI chip for device charge management and ultra-fast charging, and finally the PLL and TCXO clock combo for perfect signal synchronization.
Unbeatable speed of charging
The DAC therefore incorporates components that allow it to charge its battery extremely quickly. It supports both MTK-PE and QC2.0 technologies. It is thus possible to recharge the DX120 at 12V or 9V 1.5A, while remaining compatible with a more conventional 5V charge. These technologies allow a complete charge in only 2 hours, and then enjoy many hours of reading.
A beautiful touch screen for easy use
The DX120 is equipped with a beautiful 3.2" touch screen for a 480*800px resolution. As an IPS slab, it has high contrast, high brightness and above all wide viewing angles, allowing comfortable use, even in daylight and outdoors.
Equipped with the all-new Mango OS
The iBasso player carries the brand's latest operating system: Mango OS. It is still based on Linux but has been largely optimized and specially designed for portable audio systems. A GPU and Open GL technology have also been implemented in the device to relieve the CPU and ensure smooth navigation. In addition, the DMA (Direct Memory Access) process is used to quickly perform background tasks without cluttering the CPU unnecessarily. This gives the CPU more free computing power to decode audio files.
The iBasso DX120's Jack outputs are not compatible with headphones and headphones with a TRRS Jack connector (3 separations on the Jack, for microphone or built-in volume control). If you have headphones or headphones with TRRS jack, it is necessary to use an adapter (sold separately, available as an accessory).
Product typeDAP
OSMango OS
DACAK4495
Outputs1x Balanced Jack 2.5mm
1x Single-Ended Jack 3.5mm
1x Line Out Jack 3.5mm
1x Coaxial
ScreenÉcran IPS capacitif 3.2" 480*800px
Sampling ratePCM up to 32bit 384kHz
Native DSD up to DSD128
System clockTCXO and PLL
USB DAC FunctionUSB XMOS XU208 Interface, USB Thesycon driver
StorageSHDC and SDXC up to 2TB (not included)
Output voltageBalanced Jack 2.5mm : 3.6Vrms
Single-Ended Jack 3.5mm : 1.8Vrms
Line Out Jack 3.5mm : 1.8Vrms
Frequency responseBalanced Jack 2.5mm : 10Hz-45kHz +/-1dB
Single-Ended Jack 3.5mm : 10Hz-45kHz +/-1dB
Line Out Jack 3.5mm: 10Hz-45kHz +/-1dB
THD+NBalanced Jack 2.5mm : 0.00028%, -111dB (without load) / 0.00032%, -110dB (32 Ohm @ 2.4Vrms)
Single-Ended Jack 3.5mm : 0.00042%, -107dB (without load) / 0.00056%, -105dB (32 Ohm @ 1.2Vrms)
Line Out Jack 3.5mm : 0.00042%, -107dB (without load)
DNRBalanced Jack 2.5mm : 117dB
Single-Ended Jack 3.5mm : 115dB
Line Out Jack 3.5mm : 115dB
SNRBalanced Jack 2.5mm : 117dB
CrosstalkBalanced Jack 2.5mm : -116dB
Single-Ended Jack 3.5mm : -115dB
Output impedanceBalanced Jack 2.5mm : 0.36 Ohm
Single-Ended Jack 3.5mm : 0.24 Ohm
Autonomy16h in playback
Battery3.8V 3700mAh Li-Polymer
Quick ChargeQuick Charge 2.0 / MTK-PE
Dimensions63 x 113 x 15mm
Weight165g
ColorBrown
Package1x iBasso DX120
1x Protection case
1x Screen protector
1x USB-C Cable
1x Coaxial Câble
InputMicro SD
OutputJack 2.5mm
OutputJack 3.5mm
DAC / ADC ChipAK4495
Max sampling rateDSD128
Max sampling rate384kHz
ColorOther
ColorBrown
4 reviews
Un excellent DAP
Suite à la bonne réception, découverte, prise en main et premières utilisations du baladeur iBasso DX120 et des écouteurs iBasso IT01...un petit retour d’expérience qui peut-être apportera un complément aux divers avis et autres "unboxing vidéos" vus sur la toile ;)
Partant d’un baladeur Fiio X3 (1ère génération, remplissant bien son job mais devenant limité et avec de simples écouteurs semi intra auriculaires plats lambda).. j’ai nulle doute, atteint gros "gap" qualitatif et ergonomique indiscutable.
Commençons par les écouteurs iBasso IT01 : l’appréhension sur l’inconfort que j’avais vis-à-vis de la pénétration nécessaire des écouteurs intra-auriculaires s’est rapidement dissipée.. grâce notamment aux multiples disponibilités d’embout mis à disposition et les possibilités de pouvoir changer à sa convenance ces derniers.. Après les avoir tous essayé, mon choix a retenu la paire "à mémoire de forme". Côté restitution sonore, à chaque fois que j’utilise ces écouteurs le rendu est chaque fois meilleur !) À ce titre, un rodage est évidemment nécessaire (comme pour tout HP.. quelque soit sa taille et ici, cela se vérifie aussi ;).
Concernant le baladeur lui-même, le fait qu’il puisse lire tous mes fichiers (wave, flac, DST et DSD) sans difficulté et respect qualitatif est très très bon et bien évidemment, excellent sur du DSD ;)
Les sorties audio dédiées : "casque" (ainsi qu’une mini 2,5 que je n’ai pas pu essayer), "Line out" et "coaxial" sont également bien pensées.
Toutefois, si la sortie casque et la sortie coaxiale sont excellentes voire magistrales, je mettrais un certain bémol quant au niveau du volume de la sortie "Line out", que je trouve assez faible.
Là pour le coup, le niveau de cette même sortie, sur le Fiio X3 (qui dispose des mêmes sorties) est supérieur. J’en suis assez surpris.. je ne l’aurais pas cru, surtout vis-à-vis des autres sorties.
En effet, lorsque je relie la sortie "Line out" du iBasso sur un ampli ou une enceinte nomade (par un câble mini jack-mini jack ou par un câble mini jack-cinch) il faut augmenter significativement les niveaux des volumes, aussi bien du baladeur que celui de l’ampli (essais effectués sur divers amplis, sur une entrée aux d’un auto-radio ainsi que sur une enceinte portative). Mais le rendu qualitatif sonore est heureusement toujours bien présent !)
La coque de protection du iBasso fournie en PVC, transparente, est assez bien conçue malgré qu’il n’y ait pas de protection pour le dos.. c’est dommage. Toutefois, après m’être dirigé vers une "coque MITER" certes d’aspect assez classe, j’en suis revenu ; car celle-ci reste fine et moins protectrice contre d’éventuels petits chocs que la coque d’origine du iBasso, qui, bien plus "dure", a l’avantage de bien envelopper et protéger la totalité externe (côtés, angles et toutes les entrées & sorties) du baladeur.
Côté câbles fournis, je me pose toujours un peu la question de la pertinence du l’utilisation du (joli) petit câble de rodage (..?) visiblement sur le site du constructeur la chose est prévue, mais bon..
Le câble de la sortie coaxiale (se terminant en sortie femelle) est de toute beauté, de bonne facture, mais un peu court et implique donc une "rallonge" nécessaire ;) À noter toutefois que pour lui associer, il faut un câble coaxial avec un embout RCA femelle - mâle (ce qui n’est pas évident à trouver).. Par ailleurs, le diamètre du trou de l’entrée coaxial de la coque d’origine se révèle toutefois un peu petit pour accueillir l’adaptateur fourni par iBasso.. à moins bien évidemment de retirer la coque. Pour ces deux raisons j’utilise donc un autre adaptateur et un bon câble coaxial avec RCA classique (mâle-mâle).
Le iBasso se révèle être un baladeur vraiment "audiophile" de qualité, simple d’utilisation, pouvant lire des fichiers wave, flac DST et DSD (.dff).. et allant à l’essentiel : le SON !)
Je ne souhaitais pas les "gadgets" du wifi, du streaming et autre Bluetooth..(pour cela, mon portable me suffit amplement..).
Outre les trois sorties dédiées, le baladeur dispose aussi d’une bonne capacité de stockage car ici, avec 2 logements distincts pour insérer deux mini cartes sd à forte capacité on est plutôt bien servi !) À ce propos, le constructeur confirme la possibilité de lecture de deux cartes de 2 To...! (mais quand on regarde déjà le prix de celle de 1 To, ça calme..). Toutefois j’ai pu y introduire une carte de 64 Go (en FAT32) et une autre de 512 Go (en EXFAT), toutes deux fonctionnent sans soucis !). Ne pas hésiter de choisir des mini cartes sd de qualité.
Je recommande d’ailleurs pour accéder aux contenus, d’utiliser le menu "Répertoire" qui débouche ensuite sur le choix de "SD 1" ou "SD 2", où l’on peut retrouver SES différents dossiers et fichiers.. tels que l’on les a téléchargés SANS que le baladeur par un autre menu, scanne lui-même les cartes et décline un certain "désordre à sa sauce". J’ai essayé une fois de scanner une carte SD par le menu pour voir.. je déconseille !
La fonction "Répertoire" est simple, directe et respectueuse de son propre ordre, c’est beaucoup plus cool d’utilisation pour la navigation ;)
Pour chacun des dossiers (si c’est bien sûr pas une compilation qui ne reprendra pas forcément les "tags" des différentes pochettes) une fois dedans, après avoir enclenché la lecture d’un fichier apparaîtra comme il se doit, la pochette de l’album joué (quelque soit le format du fichier).
De plus, on a la possibilité d’ajuster le rendu sonore par certaines fonctionnalités. Par un "Égaliseur" d’abord, à 10 bandes personnalisables ou bien utiliser les modes pré-enregistrés (Classique, Pop, Dance, Rock et Basse) mais à ce moment-là, on perd un peu de volume et je trouve que l’enregistrement perd un peu de son authenticité.. je ne l’active donc pas. Par contre, le baladeur propose d’intéressants "Filtres numériques" (dont le très qualitatif "Filtre à pente très douce") et enfin, de différents "Mode sonore" parmi lesquels le mode "Original" est très convaincant :)
Dernier point, la batterie : ne disposant pas de "chargeur rapide", j’utilise pour l’instant le simple chargeur de base d’un iPhone. Le temps de charge du baladeur met un certain temps.. notamment lorsque la batterie est à vide (à 0%) celle-ci comptabilise bien 5 heures pour une charge complète (à 100%). Je déconseille la charge en mode usb reliée à un ordi (à moins de le laisser tourner toute une nuit..!)
Une fois chargé, j’évalue plutôt l’autonomie à 12-13 bonnes heures d’écoute, plutôt que 16 (plébiscitées par le constructeur).
Enfin, je préconise le transfert des dossiers/fichiers sur la micro carte sd en l’insérant dans un ordinateur, ce qui est beaucoup plus rapide, plutôt qu’un transfert via le cordon usb relié au baladeur qui reste une pratique très chronophage.
Pour donc une utilisation simple, allant à l’essentiel, de très bonne qualité, en mode "nomade" comme "sédentaire" et d’un bon rapport qualité/prix, ce iBasso DX 120 rempli avec pertinence mon cahier des charges !)
Je suis globalement très satisfait :)
This review has been posted for IBASSO DX120 DAP HiFi Music Player DAC AK4495 32bit 384kHz DSD128 Brown
Très satisfait
Ce lecteur remplace mon vieux Cowon S9 (merci à lui). Bien sûr les différences sont flagrantes : le rendu est plus clair avec plus de détails, la dynamique est accrue. Ce n'est pas la révolution mais une belle évolution. L'interface à peu évolué depuis par rapport au Cowon bien que près de 10 ans séparent les 2 appareils...
J'utilise le casque Final F7200 qui est excellent.
Achetez le les yeux fermés c'est du lourd pour son prix
UN SANS FAUTE
Acheter le les yeux fermés, en quelques mots un son parfait à mon goût différent filtres pour modifier le son, puissance largement suffisant pour alimenter intra et casque autonomie bonne simplicité d utilisation, une belle réussite
Du bon
Bonjour,
j'ai couplé ce DX120 avec un intra Ibassi IT04, il contient deux microSD de 200G chacune tous style musical.
Venant d'un DX80, je trouve que le 120 est plus sec au niveau du son, plus clair et moins ''tassé'' dans la restitution globale. une fois mon réglage trouvé Filtre numérique ''Filtre à pente très douce'' Mode sonore ''Référence'' (à vous de tester chacun son oreille) il est parfait et d'une qualité rare pour un produit dans cette gamme de prix.
Je conseille sans hésitation.
The iBasso DX120 is a high-end digital music player (DAP) that delivers high-flying audio performance thanks to its clever design. DAC AK4495, USB...
