IBASSO DX170 Digital Audio Player DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Black
iBasso offers with its DX170 an excellent audiophile DAP. This one benefits from a careful design, using quality components, allowing to provide a faithful, precise and dynamic sound reproduction. It also integrates practical features and uses an operating system based on Android, which is both intuitive, fast and flexible.
By buying this product you get 42 loyalty points
Reference : 16679
429,00 €tax incl.
357,50 € tax excl.
iBasso DX170
iBasso DX170 Baladeur Numérique DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Noir
FPGA Master & NDK Femtosecond clocks
The DX170 uses the FPGA-Master technology developed by iBasso. This technology, as a system controller, retrieves the audio data directly from the SoC and plays a major role in reproducing the signal and maintaining its integrity. It synchronizes and generates all the audio clocks at the same time, using two NDK femtosecond clocks, to finally obtain a single, fully synchronized clock source. The FPGA and NDK oscillators also allow for extremely low jitter, resulting in incredibly pure audio reproduction.
Dual Cirrus CS43131 DAC
The DX170 digital to analog conversion stage embeds two Cirrus CS43131 DAC chips, offering very good performances, with a dynamic range measured at 130dB and a THD+N of -115dB. This is followed by an exclusive amplification system using an AOP and buffer duo. A combination allowing the DAP to offer not only a great sound transparency, but also a beautiful musicality.
New generation of RK SoC
With the advanced processing technology of the RK3566 SoC, the system response is greatly improved. This makes it faster and smoother to use.
Sharp 1080p display
The front panel of the iBasso DX170 features a large and beautiful Sharp 1080p touch screen. This one offers a high quality image, with its 16.7 million colors, its definition of 445ppi, its brightness of 480cd/m², its sRGB gamut and its 2.5D Corning Glass.
Android 11
The DX170 uses the Android 11 operating system, which is as intuitive as it is fast. Moreover, it also allows the installation of applications (in APK format) and thus to enjoy the main streaming services.
MQA 8x decoding
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The iBasso DX270 integrates an 8x MQA decoder to read these files in order to offer the best possible audio quality.
WiFi & Bluetooth
The DX170 offers convenient wireless connectivity. It allows you to do without cables, by connecting a Bluetooth headphone and broadcasting your music via the network. In addition, the DX170's Bluetooth 5.0 transmission supports the high-resolution aptX and LDAC codecs, ensuring very good wireless sound quality.
Product typeDigital audio player (DAP)
OSAndroid 11
DAC Chip2x CS43131
Outputs1x Jack 3.5mm line / coaxial / headphone output
1x Jack 4.4mm balanced headphone output
1x USB
TouchscreenSharp 5"
1080*1920p
Native DSD up to DSD256
SoCRK3566
RAM2Go
ROM (storage)32Go
Micro SD slotSDHC & SDXC support up to 2To
WiFi802.11 b/g/n/ac (2.4GHz/5GHz)
Bluetooth version5.0
Quick chargeQC3.0
PD2.0
MTK PE Plus
USB DAC function sampling ratesPCM up to 32bit 384kHz, DSD DoP up to DSD128
Supported file formatsMQA, APE, FLAC, WAV, WMA, AAC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, CUE, ISO
Play time~ 11h
Balanced Jack 4.4mm headphone output Measurements
Output voltage6.4Vrms
Frequency response10Hz - 40kHz ±0.15dB
SNR130dB
THD+N0.00022% (no load, 3Vrms)
0.00022% (32Ω, 3Vrms)
Crosstalk-125dB
Single-ended Jack 3.5mm headphone output Measurements
Output voltage3.2Vrms
SNR125dB
THD+N0.0004% (no load, 2Vrms)
0.0007% (32Ω, 2Vrms)
Crosstalk-115dB
Line output measurements
SNR125dB
THD+N0.00035% (hors charge, 2Vrms)
Crosstalk-113dB
Dimensions124.5 x 70 x 15mm
Weight165g
Package1x iBasso DX170
1x USB-C cable
1x TPU case
Protective screens
InputWiFi
InputMicro SD
OutputUSB
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
Bon lecteur au rapport qualité / prix imbattable !
Mon feedback après 3 jours d'utilisation :
- Si je devais le comparer à mon Fiio M9, en termes d'utilisation (ergonomie et interface) nous sommes largement au-dessus, y a pas photo !
Meilleure qualité de fabrication (écran et ses couleurs, boîtier) même si j'avoue que la roulette du volume me fait toujours aussi peur (sur ce sujet, j'aime le concept des Fiio M11 Plus).
- En termes de sonorité, le son est doux (non-agressif), chaud (mais non basseux) et bien défini, comme j'aime !
Je retrouve le M9 mais en beaucoup plus amélioré, meilleure définition, meilleure aération (entre les instruments, on entend tout), et surtout meilleure largeur de scène. Les basses sont propres et ne prennent pas le dessus, les médiums sont parfaits (en entends bien les voix, ou les instruments à cordes comme la guitare), les aigus biens présents mais jamais agressifs.
On est vraiment bien au-dessus du M9 !!! De plus, il semble avoir beaucoup de puissance à revendre, je suis toujours en Gain Low, et je ne dépasse jamais le niveau de volume 50 avec mon Meze 99 Classics (branché en symétrique), sinon ça devient vitre trop fort !
- Maintenant, si je devais le comparer au Shanling M6U que j'ai gardé 10 jours, encore une fois je préfère le DX170, plus léger, plus nomade, et surtout beaucoup moins agressif en termes de sonorité (le M6U me provoquait très rapidement de la fatigue auditive, ce que je ne rencontre pas avec le DX170).
Les reproches :
- Filtres de protection d'écran (inclus) de très mauvaise qualité
- Manque de RAM
- Le Wifi a l'air d'être limité (par exemple j'ai galéré à télécharger la mise à jour)
 (3)
This review has been posted for IBASSO DX170 Digital Audio Player DAP 2x CS43131 Bluetooth 5.0 aptX LDAC WiFi Android 11 Black
iBasso offers with its DX170 an excellent audiophile DAP. This one benefits from a careful design, using quality components, allowing to provide a...
