IBASSO DX320 EDITION X Digital Audio Payer DAP Balanced 2x BD34301EKV Bluetooth 5.0 WiFi 5G MQA 16x Black
To commemorate the 10th anniversary of the DX320 Walkman and the 16th anniversary of the brand, iBasso is releasing a limited edition of only 500 copies of the beautiful DX320 Edition X ! This brand new version unveils a different design, made from a "liquid" effect metal alloy. With soft lines and curves that intersect and blend into each other, the DX320 Edition X offers an innovative, decidedly modern aesthetic, the appearance of which has been patented by the brand in 2020.
By buying this product you get 199 loyalty points
Reference : 16858
1 990,00 €tax incl.
1 658,33 € tax excl.
iBasso DX320 Edition X
iBasso DX320 Edition X Baladeur Numérique DAP Symétrique
For the rest, the DX320 Edition X takes the excellent internal architecture of the standard version. As a high-end digital music player, the iBasso DX320 Edition X has an extremely careful design, thought to offer the best sound performances for an outstanding musical experience. Powerful and full of features, the DX320 Edition X is the perfect companion for listening at home or on the go.
FPGA Master
At the heart of the DX320 Edition X is an FPGA-Master designed specifically for these models. The role of the FPGA-Master is to recover the audio data sent by the SoC in order to maintain a clean and stable signal. Combined with two Accusilicon clocks (45.1584M and 49.152M), it generates and perfectly synchronises the clock signals. In short, it ensures a drastic reduction in jitter to provide an extremely clean digital audio signal.
iBasso DX320 FPGA MASTER
Qualcomm Snapdragon 660 processor
The integrated 8-core Qualcomm Snapdragon 660 processor, etched in 14nm, offers incredible power to efficiently process audio signals while allowing smooth navigation within the device's interface. This SoC is combined with 6GB of RAM and 128GB of storage (ROM) (expandable via Micro SD card not included).
iBasso DX300 Baladeur Numérique DAP Symétrique 4x CS43198 FPGA Bluetooth 5.0 WiFi
Dual battery
The DX320 Edition X's power stage incorporates two independent batteries. The first powers the digital stage, while the second powers the headphone amplifier. This separation of the power supplies limits possible interference between the digital and analogue circuits in order to reduce the level of distortion as much as possible.
ROHM BD34301EKV Dual DAC
No less than two RHOM BD34301EKV DACs are used in the digital/analogue conversion stage of the iBasso DX320 Edition X, for a total of 4 conversion channels. These combined channels allow the DAP to have a totally symmetrical conversion circuit while favouring its sound performance.
Technical specificationss
Type of productDigital music player (DAP)
Input1x Slot Micro SD
Outputs1x 2.5mm balanced jack
1x 4.4mm balanced jack
1x 3.5mm unbalanced jack
1x 3.5mm coaxial jack
Other connectors1x USB-C 3.1 SuperSpeed
Connectivity802.11 b/g/n/ac (2.4GHz/5GHz) 2x2MIMO 5G WiFi
Bluetooth 5.0
DAC chips2x RHOM BD34301EKV
FPGA
RAM6Go
ROM (Storage)128Go
Touch screen6.5" IPS Full Screen
2340 x 1080 pixels
Battery4000mAh 3.8V + 2000mAh 3.8V
Charging time2.5h
Autonomy10h
Supported audio formatsMQA 16x, APE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST, CUE, ISO, M3U, M3U8
measures Balanced outputs 4.4mm jack / 2.5mm jack
Maximum output level7.1Vrms
Power output1200mW @ 32Ω
168mW @ 300Ω
Frequency response10Hz - 40kHz ±0.3dB
SNR125dB
Dynamic range-125dB
THD+N-112dB (no load, 2.8Vrms)
-110dB (300Ω)
-103dB (32Ω)
Separation of channels-120dB
Impedance0.38Ω
Measures unbalanced output 3.5mm jack
Maximum output level3.5Vrms
Power output380mW @ 32Ω
40mW @ 300Ω
SNR122dB
Dynamic range-122dB
THD+N-110dB (hors charge, 2Vrms)
-110dB (300Ω)
-99dB (32Ω)
Separation of channels-114dB
Impedance0.34Ω
measures Balanced line output 4.4mm jack / 2.5mm jack
SNR125dB
Dynamic range-125dB
THD+N-110dB (hors charge, 2.8Vrms)
Measures unbalanced line output 3.5mm jack
SNR122dB
Dynamic range-122dB
THD+N-108dB (hors charge, 2Vrms)
Separation of channels-110dB
general
Power supplyVia USB-C
Chassis materialMetal alloy
ColorSilver
Dimensions162*77*17mm
Weight368g
Package1x iBasso DX320 Edition X + AMP11 MK2
1x USB-C cable
1x Coaxial cable
1x Protective case
1x Screen protector
InputWiFi
InputMicro SD
OutputCoaxial SPDIF
OutputJack 4.4mm
OutputJack 3.5mm
OutputJack 2.5mm
DAC / ADC ChipROHM BD34301EKV
Max sampling rate384kHz
Max sampling rateDSD128
ColorSilver
To commemorate the 10th anniversary of the DX320 Walkman and the 16th anniversary of the brand, iBasso is releasing a limited edition of only 500...
