FX-AUDIO R07 Balanced Headphone Amplifier
The FX-Audio R07 headphone amplifier is a balanced desktop headphone amplifier featuring quality components such as AOP OPA1612. The R-07 is part of FX-Audio's "GOOD TIMES" range. This is a range of aesthetically pleasing devices with demanding components.
Reference : 18642
129,00 €tax incl.
107,50 € tax excl.
FX-AUDIO R07 Amplificateur casque symétrique OPA1612 2000mW / 32 Ohm
Photo of FX-AUDIO R07 balanced headphone amplifier
The FX-Audio R07 headphone amplifier is a balanced desktop headphone amplifier featuring quality components such as operational amplifiers OPA1612. The R-07 is part of FX-Audio's "GOOD TIMES" range. This is a range of aesthetically pleasing devices with demanding components. Indeed, the form factor of this headphone amplifier is innovative thanks to its vertical design. Connectivity features two stereo inputs on RCA and XLR connectors, plus 3 outputs, 2 of which are balanced: 6.35mm jack, 4.4mm jack and 4-pin XLR.
Please note that the 4.4mm Jack and XLR outputs are connected internally. Therefore, connecting two headphones simultaneously to these outputs may cause the unit to break.
FX-Audio R07: OPA1612
The R07 headphone amplifier incorporates ultra-low-noise, ultra-low-distortion OPA1612 dual operational amplifiers. This AOP features independent circuits to limit crosstalk and avoid interactions between each channel.
Exploded view of the FX-AUDIO R-07 balanced headphone amplifier
Aperçu de l'amplicateur casque FX-Audio R-07
Input/output diagram for the FX-AUDIO R-07 balanced headphone amplifier
1Volume control
2XLR 4-pin balanced headphone output
3Balanced 4.4mm headphone output
46.35mm headphone output
5XLR stereo input
6RCA stereo input
7Source selector
8Output selector
9Gain selector
10IEC power supply / Power switch
Amplification componentsOPA1612
Inputs1x RCA stereo input
1x XLR balanced stereo input
Outputs1x 6.35mm jack output
1x 4.4mm balanced jack output
1x XLR 4-pin balanced output
GainLow : 0dB High : 6dB
Volume control
MEASUREMENTS OF JACK 6.35 OUTPUT / GAIN 0DB
SNR 120.5dB
ImpedanceTHD+NOutput power
16 Ohm0.00025%257mW
32 Ohm0.00019%131mW
64 Ohm0.00018%66.3mW
150 Ohm0.00018%28.5mW
300 Ohm0.00018%14.5mW
600 Ohm0.00018%7mW
MEASUREMENTS OF BALANCED JACK 4.4MM AND XLR OUTPUTS / GAIN 0DB
SNR 117.6dB
16 Ohm0.00082%1027mW
32 Ohm0.00046%525mW
64 Ohm0.00034%266mW
150 Ohm0.00028%115mW
300 Ohm0.00026%56.5mW
600 Ohm0.00026%28.4mW
6.35 JACK OUTPUT MEASUREMENTS / 6DB GAIN
SNR 119.8dB
16 Ohm0.00038%1035mW
32 Ohm0.00029%5251mW
64 Ohm0.00028%267mW
150 Ohm0.00026%114mW
300 Ohm0.00026%57.3mW
600 Ohm0.00018%28.5mW
MEASUREMENTS OF BALANCED JACK 4.4MM AND XLR OUTPUTS / GAIN 6DB
SNR 119.5dB
16 Ohm0.00093%2008mW
32 Ohm0.00046%2095mW
64 Ohm0.00034%1058mW
150 Ohm0.00025%459mW
300 Ohm0.00021%228mW
Power supplyAC 100-240V
Dimensions120 x 80 x 135mm
Weight984g
Package1x FX-Audio R07 headphone amplifier
1x RCA-RCA stereo modulation cable
1x Mains power cable (EU)
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ClassN/A
FX-AUDIO R07 Balanced headphone amplifier OPA1612 2000mW / 32 Ohm
The FX-Audio R07 headphone amplifier is a balanced desktop headphone amplifier featuring quality components such as AOP OPA1612. The R-07 is part...
