HIFIMAN EF600 Balanced Headphone Amplifier R2R DAC Bluetooth 5.0 QCC5124 aptX HD LDAC
An amazing format for an original, performing and practical product, the EF600 from HifiMan takes on the roles of balanced headphone amplifier, R2R DAC and headphone stand. Thus, in addition to offering a high quality headphone listening, it allows an obvious saving of space, ideal for an office installation.
By buying this product you get 71 loyalty points
Reference : 17495
719,00 €tax incl.
599,17 € tax excl.
Shipping date: 13-05-2025.
HiFiMan EF600
Amplificateur Casque DAC R2R Symétrique Bluetooth aptX HD LDAC
HiFiMan EF600 Amplificateur Casque DAC R2R Symétrique Bluetooth aptX HD LDAC
R2R Ladder DAC
Unlike many DACs on the market that use delta-sigma digital-to-analog conversion chips, the EF600 chooses to use the R2R ladder conversion method. This particular approach uses a network of high precision resistors for a musical, lively and clear listening.
Bluetooth HD Reception
Wirelessly connect a source such as a smartphone or tablet directly to the EF600 via its Bluetooth receiver. Stream and control your music remotely and take advantage of the high-resolution aptX HD and LDAC transmission codecs for accurate sound reproduction.
Balanced or single-ended, you choose
Both on the input and output sides, the HifiMan EF600 offers balanced and single-ended connections. Thus, on the input side, in addition to its digital connections in coaxial, USB-C and USB-B format, the device provides balanced XLR and single-ended RCA. In the same way, for its outputs, the EF600 provides balanced XLR 4 pins and unbalanced Jack 6.35mm for the headphone output, and balanced XLR and unbalanced RCA for the line output.
A lot of power to spare
With no less than 5W under 32Ω (balanced) available for each channel, the HiFiMan does not lack power. It will therefore have no trouble accompanying the vast majority of headphones, including the most demanding high-impedance models.
Product typeBalanced headphone amplifier and R2R DAC
Headphone amplifier2x HYMALAYA PRO
Bluetooth chipBluetooth 5.0 QCC5124 (LDAC / AptX HD / AptX / AAC / SBC)
InputsBluetooth
1* USB-B
1* Coaxial
1* USB-C
1* Balanced stereo XLR
1* Single-ended stereo RCA
Outputs1* Single-ended Jack 6.35mm headphone output
1* Balanced XLR 4 pins headphone output
1* Balanced stereo XLR line out
1* Single-ended stereo RCA line out
Headphone output impedance2x5.12W @ 32Ω, balanced
2x 1.8W @ 32Ω, single-ended
SNR118dB
Channel separation131dB ±3dB
THD+N (line out)0.0014% (-8dB)
Supply voltage210-230VAC 50Hz
Dimensions104*165*283mm
ColorSilver
InputXLR
OutputJack 6.35mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateNC
ColorSilver
ClassN/A
An amazing format for an original, performing and practical product, the EF600 from HifiMan takes on the roles of balanced headphone amplifier, R2R...
