LITTLE DOT ZERO DAC Headphone Amplifier 1T4 Tubes Bluetooth 5.0 aptX HD LDAC 24bit 192kHz
The Little Dot Zero is a desktop DAC and headphone amplifier combo, whose amplification stage is powered by a pair of 1T4 tubes. These allow it to reveal a sound that is both warm and fine, highlighting a great musicality.
Reference : 16060
189,00 €tax incl.
157,50 € tax excl.
Last items in stock !
Shipping date: 08-05-2025.
Little Dot Zero
DAC Amplificateur Casque à Tubes 1T4 Bluetooth 5.0 aptX HD LDAC 24bit 192kHz
The Little Dot Zero is a desktop DAC and headphone amplifier combo, whose amplification stage is powered by a pair of 1T4 tubes. These allow it to reveal a sound that is both warm and fine, highlighting a great musicality. The Little Dot Zero also includes a digital/analog conversion stage, allowing it to offer a USB-B input and a Bluetooth 5.0 reception, in addition to its line input in 3.5mm jack format. In addition, the Bluetooth chip used supports high resolution transmission codecs such as aptX HD or LDAC, the latter supporting sampling rates up to 24bit 96kHz. Finally, the Little Dot Zero has a dual headphone output with 3.5mm and 6.35mm jacks.
Product typeDAC and headphone amplifier
InputsBluetooth 5.0
1x USB-B
1x Jack 3.5mm
Outputs1x Jack 3.5mm headphone output
1x Jack 6.35mm headphone output
Tubes2x 1T4
Supported Bluetooth codecsSBC, AAC, aptX LL, aptX HD, LDAC
Supported sampling ratesBluetooth : PCM up to 24bit 96kHz (LDAC)
USB : PCM up to 24bit 192kHz
Distortion0.1% (1000Hz)
SNR98dB
Frequency response20Hz - 20kHz (-0.2dB)
10Hz - 50kHz (-1.2dB)
Output power1.8W @ 32Ω
0.8W @ 120Ω
0.3W @ 300Ω
Dimensions140 x 108 x 75mm
Weight500g
InputJack 3.5mm
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipNC
Max sampling rate192kHz
ColorSilver
ClassTube amp
The Little Dot Zero is a desktop DAC and headphone amplifier combo, whose amplification stage is powered by a pair of 1T4 tubes. These allow it to...
