P1 Headphone Amplifier and regulated linear power supply
Reference : 9469
149,00 €tax incl.
124,17 € tax excl.
Here is a headphone amplifier with its linear regulated power supply, allowing you to enjoy your HiFi headphones in the best ways. It has a headphone output jack 6.35mm, as well as 4 possible gain levels: 0dB / 10dB / 18dB / 20dB. Its RCA Stereo input allows you to connect your vinyl turntable, CD player, or DAC. The power cable and the cable to connect the 2 devices are provided.
Thehas design and manufacture are neat and irreproachable, the best components have been chosen. As an example, this regulated linear power supply generates an ultra-clean current and voltage without any external interference.
Specifications:
  • Chassis complete aluminum, machined CNC (CNC machine)
  • Output Power: 300 Ohm (320mW) / 60 Ohm (580mW)
  • Output Impedance: 10 Ohm
  • Signal to noise ratio: -101.2dB
  • Frequency response: 20Hz - 30kHz
  • Distortion: 0.0015%
  • Stereo RCA Input (Red and White)
  • Headphone Jack 6.35mm
  • Power supply: 220-240V (Power cable included)
  • Headphone amp size (with buttons): 177x190x60mm
  • Power supply: 177x160x66mm
  • Weight of the set: 3.5kg
[Img-9008-left-thickbox_default]
