Site très réactif. Beaucoup de choix à des prix raisonnables. Le suivi des envois est très pratique. Vraiment un bon site. Je recommande
By buying this product you get 59 loyalty points
Discrete Balanced Headphone Amplifier Preamplifier Black
Topping returns with the A90 Discrete, an improvement of the previous A90, this time equipped with discrete components. Both a headphone amplifier and a preamplifier, it incorporates a discrete NFCA amplifier stage capable of supporting most headphones on the market. Its careful design using many high-end components allows it to deliver a rich, clear and transparent sound.
Topping's A90 Discrete features a Nested Feedback Composite Amplifier (NFCA) stage based on the use of discrete components. The four integrated discrete NFCA modules each use 39 transistors in a balanced design. The optimized hybrid voltage/current feedback architecture and Ultra High Gain Feedback (UHGF) technology provide excellent DC and AC performance. With this new design, the A90 Discrete benefits from high output power, allowing it to accompany both high-sensitivity headphones and high-impedance headphones effortlessly. Precisely matched ultra-low noise transistors connected in parallel ensure extremely low noise and distortion.
The Topping A90 Discrete offers both high output voltage and current. The former allows the amplifier to accompany high impedance headphones without difficulty, while the latter provides sufficient power for low sensitivity headphones.
The unit also offers two different gain settings to accommodate an ever-growing array of headphones: low gain for high-sensitivity headphones, high gain for the most demanding headphones. Combined with a noise level of only 0.2µVrms, even the most sensitive IEMs will not suffer from any noise.
A ground loop can occur when several devices are used together. Therefore, the A90 Discrete provides a GND/LIFT switch to solve this problem. In normal use, if no sound fault occurs, the switch can be set to GND. Otherwise, if a ground loop is encountered, the switch should be set to LIFT.
In addition to its headphone amplifier section, the A90 Discrete includes a preamp circuit. In preamp mode, you get the same performance as in headphone amplifier mode. The single-ended 20Ω and balanced 40Ω outputs allow to accompany many amplifiers. Moreover the two modes can be used simultaneously and the remote control allows to access each function easily.
The A90 Discrete is equipped with a 12V trigger that can work as an active control (trigger output) or passive control (trigger input). Thus, the A90 Discrete can be switched on and off in full synchronization with other 12V triggered devices in your audio system.
The Topping A90 Discrete uses an R2R volume control, composed of relays and resistors. It offers extremely precise control, perfect channel balance and excellent durability.
The A90 Discrete can be combined with the Topping EXT90, the latter offering a possibility of extension of the connectivity of the device. With the EXT90 connected, you will have four XLR inputs and two RCA inputs in total..
The Topping EXT90 is sold separately.
1 | Input LED |
2 | Output LED |
3 | IR Receiver |
4 | Power LED |
5 | Volume indicator |
6 | Balanced XLR 4 pins headphone output |
7 | Balanced Jack 4.4mm headphone output |
8 | Single-ended Jack 6.35mm headphone output |
9 | Multi-function button |
10 | USB interface for firmware update |
11 | Balanced XLR input |
12 | Balanced XLR output |
13 | 12V Trigger interface |
14 | Power connector |
15 | Extension interface |
16 | Single-ended RCA input |
17 | Single-ended RCA input |
18 | GND/LIFT Switch |
19 | Power switch |
" From design point of view, this is another watershed audio/engineering event brought to us by Topping. Who would have thought that this company would keep breaking new ground instead of all the major/usual names we know in hi-fi. It is my pleasure to add Topping A90 Discrete headphone amplifier/pre-amplifier to my recommended list. "
Product type | Headphone amplifier Preamplifier |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA 1x Balanced Jack 4.4mm headphone output 1xBalanced XLR 4 pins headphone output 1x Single-ended Jack 6.35mm headphone output |
Discrete headphone amplifier performance | ||||
SE Input/ SE Output | BAL Input / SE Output | SE Input / BAL Output | BAL Input / BAL Output | |
THD+N @ 1kHz (A-Weighting) | < 0.000065% @ 500mW, 32Ω | < 0.00008% @ 500mW, 32Ω | < 0.000065% @ 2000mW, 32Ω | < 0.00008% @ 2000mW, 32Ω |
< 0.000055% @ 80mW, 300Ω | < 0.00006% @ 80mW, 300Ω | < 0.000055% @ 320mW, 300Ω | < 0.00006% @ 500mW, 300Ω | |
THD+N @ 20Hz-20kHz (90kBW) | < 0.0003% @ 500mW, 32Ω | < 0.0003% @ 500mW, 32Ω | < 0.0006% @ 2000mW, 32Ω | < 0.0006% @ 2000mW, 32Ω |
< 0.00025% @ 80mW, 300Ω | < 0.00025% @ 80mW, 300Ω | < 0.00025% @ 320mW, 300Ω | < 0.00025% @ 320mW, 300Ω | |
SNR @ Max Out, 1kHz (A-Weighting) | 141dB | 137dB | 145dB | 138dB |
Dynamic range @ 1kHz (A-Weighting) | 141dB | 137dB | 145dB | 138dB |
Frequency response | 20Hz-40kHz (±0.1dB) | 20Hz-40kHz (±0.1dB) | 20Hz-40kHz (±0.1dB) | 20Hz-40kHz (±0.1dB) |
Output level | 25Vpp | 25Vpp | 49Vpp | 49Vpp |
Measured noise level @ A-Weighting | < 0.7µVrms @ G=L | < 0.7µVrms @ G=L | < 1µVrms @ G=L | < 1µVrms @ G=L |
< 1.1µVrms @ G=H | < 1.1µVrms @ G=H | < 1.8µVrms @ G=H | < 1.8µVrms @ G=H | |
Actual noise level @ A-Weighting | < 0.2µVrms @ G=L | < 0.2µVrms @ G=L | < 0.7µVrms @ G=L | < 0.7µVrms @ G=L |
< 0.6µVrms @ G=H | < 0.6µVrms @ G=H | < 1.6µVrms @ G=H | < 1.6µVrms @ G=H | |
Channel crosstalk @ 1kHz | -107dB | -105dB | -116dB | -113dB |
Input sensitivity | 9.1Vrms @ G=L | 9.3Vrms % @ G=L | 9.1Vrms % @ G=L | 9.3Vrms % @ G=L |
3Vrms @ G=H | 3Vrms @ G=H | 3Vrms @ G=H | 3Vrms @ G=H | |
Gain | 0db @ G=L | -0.2dB @ G=L | 6dB @ G=L | 5.8dB @ G=L |
9.5dB @ G=H | 9.3dB @ G=H | 15.5dB @ G=H | 15.3dB @ G=H | |
Output power | < 0.1Ω | < 0.1Ω | < 0.2Ω | < 0.2Ω |
Output impedance | 2x 3300mW @ 16Ω, THD+N < 0.1% 2x 2000mW @ 32Ω, THD+N < 0.1% 2x 1100mW @ 64Ω, THD+N < 0.1% 2x 250mW @ 300Ω, THD+N < 0.1% | 2x 9800mW @ 16Ω, THD+N < 0.1% 2x 6700mW @ 32Ω, THD+N < 0.1% 2x 4000mW @ 64Ω, THD+N < 0.1% 2x 1000mW @ 300Ω, THD+N < 0.1% 2x 500mW @ 600Ω, THD+N < 0.1% | ||
Load impedance | > 8Ω |
Discrete preamplifier performances | ||||
SE Input / SE Output | BAL Input / SE Output | SE Input / BAL Output | BAL Input / BAL Output | |
THD+N @ 1kHz (A-Weighting) | < 0.000055% | < 0.00006% | < 0.000055% | < 0.00006% |
THD+N @ 20Hz-20kHz (90kBW) | < 0.00025% | < 0.00025% | < 0.00025% | < 0.00025% |
SNR @ 1kHz (A-Weighting) | 141dB | 137dB | 145dB | 138dB |
Dynamic range@ 1kHz (A-Weighting) | 141dB | 137dB | 145dB | 138dB |
Load impedance | 20Ω | 20Ω | 20Ω | 20Ω |
Supply voltage | 100-240VAC 50/60Hz |
Dimensions | 222 x 160 x 45mm |
Color | Black |
Package | 1x Topping A90 Discrete 1x Remote control 1x Powre cable 1x Male Jack 6.35mm to female Jack 3.5mm adapter |
Input | XLR |
Input | RCA |
Output | XLR |
Output | Jack 4.4mm |
Output | RCA |
Output | Jack 6.35mm |
Color | Black |
Class | Class A / AB |
Remote Control | Yes |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
JEAN-MARC M.
David A.
Jerome V.
