LITTLE DOT MKIII SE Tube Balanced Class A Headphone Amplifier
The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature specific to tube devices, namely a warm but extremely detailed sound. This version adds balanced input and output connections as well as a discrete Class A output stage.
Reference : 14065
699,00 €tax incl.
582,50 € tax excl.
Little Dot MKIII SE
Amplificateur Casque Class A Symétrique à Tubes
The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature specific to tube devices, namely a warm but extremely detailed sound. This version adds balanced input and output connections as well as a discrete Class A output stage. The rear panel therefore features RCA Stereo and XLR inputs and the front panel features 6.35mm and XLR 4 pin Jack and XLR outputs. Unlike its big brother, the MKIII SE uses hybrid amplification, based on both a pair of 6N tubes (6922/ECC88) and Solid-State electronic components.
The amplifier also offers a gain that can be adjusted to two positions (x4.5 and x9) using the jumper. By default the amplifier is set to gain x4.5.
All components are integrated in a beautiful and robust Aluminium housing, the tubes being protected by brass cages offering a vintage look to this amplifier. The power supply is directly integrated into the device, also under an Aluminium bell.
Unlike the MKIII, the MKIII SE works only as a headphone amplifier, not as a combo amplifier + preamplifier. This one does not have any output other than the headphone outputs on the front panel.
Little Dot MKIII SE review by Soundphile Review
" The MKIII SE is just a fabulous headphone amplifier that exceeds every expectation "
Test du Little Dot MKIII SE par Soundphile Review
Amplification typeClass A Tube amplifier
Amplification designBalanced
Tubes2x 6N11
Frequency response5Hz - 100kHz (-1dB)
THD+N0.001% (2Vrms @ 1000Hz)
Output power2.5W @ 32Ω
1.8W @ 120Ω
800mW @ 300Ω
Switchable gainLow : 4.5
High : x9
Recommended load impedance32Ω - 300Ω
Input impedance50kΩ
Consumption30W
Case materialAluminium
Dimensions (LxPxH)165 x 245 x 120mm
Weight3kg
ColorSilver and black
InputXLR
OutputJack 6.35mm
ColorSilver
ClassClass A / AB
ClassTube amp
2 reviews
Méchant !! ^^
Mdr au début je voulais le refourgué car c'étais vraiment pas terrible et pis je me suis fais une raison ( patience du rodage ) au moins 150 / 200 h et pfiouf ( avec de bon tube (gold lion dans mon cas )
Mon intérêt pour cet ampli l'a emporter en comparaison avec le Xduoo ta 20 plus dans les paramètre de fourchette de prix , puissance , lampe , hybride , full symétrique ; sinon LD meilleur en réponse de fréquence ; meilleur thd et surtout dans mon cas .....pouvoir profité de merveilleux intra ( j'aime pas les casque ) parceque cet ampli gère incroyablement bien avec même une impédance de 16 hom ....ok y'a un peu de bruit mais dés que je monte le son na pu de bruit....mais un orgasme auditif ^^
donc dans mon cas il est couplé avec un fiio k9 ess pro en symétrique lol banché sur audirvana et dans les oreilles un merveilleux fiio fh9 plus tout un tas d'accessoire occulte d'audiophile histoire de bonifier ça ;)
pis c'est la claque ..y'a un peu plus de vie et de chaleur avec les lampes mais c'est gentil ....rien a voir avec les ampli full lampe donc ...par contre il envoi méchamment la purée et y'a rien de mou pour les style de son électro de fou furieux ( quand le kick tape je suis entre l'enclume et le marteaux c'est du pur délire )
meilleur imagerie espacement de la sène sonore ...puissance général incroyable il est trés clair rien rédhibitoire en terme de saturation disto sur les intra et pis par contre omg cette basse et se son générale saturé... plein...beaucoup de corp il amène une super texture et définition du son... vive la classe a
et merci a l'équipe d'auiophonics
This review has been posted for LITTLE DOT MKIII SE Tube Balanced Class A Headphone Amplifier
Un régal
Associé au casque Fostex th 500 rp , il donne en 10 mn chrono ( chauffe ) un son bien défini , pas trop tubesque mais suffisamment chaud . l'étagement de la scène est parfaite , aussi bon en rca qu'en xlr ( bien câblé s'entend ) ... du détail , de l'impact ( rapidité ) ... de plus il est très mignon , semi vintage . Attention regardez les dimensions , ce n'est pas petit mini , ni léger . construction vraiment imposante ( pas du toc chinois . Notice en français à chercher sur le net ... package solide . Je suis très satisfait ... pour de longues heures .
 (3)
The Little Dot MKIII SE, the successor to the MKIII, is a tube headphone amplifier that offers excellent audio performance with a signature...
