BURSON AUDIO DA-160 DAC 24Bit/96Khz USB 24Bit/192Khz SPDIF
By buying this product you get 282 loyalty points
Reference : 6110
949,00 €tax incl.
790,84 € tax excl.
Including 1,00 € for green tax
Le Burson DA-160 est un DAC dernière génération fruit des dernières innovations de la marque.
  • Frequency response: 5Hz (-0.3dB) to 35 kHz (-1dB)
  • Signal to noise ratio: >101 dB at 0dB gain
  • THD: <0.001% at 6mW/300 Ohms
  • Channel séparation: >95dB/10kHz
  • Output impedance: line out 25 Ohms 45 Ohms (selectable)
  • Power dissipation: <25W, internal, regulated power supply
  • Dimensions: (180mm X 250mm X 80mm)
  • Poids : 5Kg
Connectique :
  • Entrées :
  • 2 x USB (24bit @ 96Khz 10ppm low jitter clock)
  • 1 x Coaxial RCA (24bit @ 192Khz)
  • 1 x Toslink / SPDIF (24bit @ 192Khz)
  • Sorties :
  • 2 x RCA output (niveau ligne ou + 6dB gain )
PDF Constructeur
https://www.audiophonics.fr/images2/6110/6110_BURSONDA160_1.jpg
https://www.audiophonics.fr/images2/6110/6110_BURSONDA160_3.jpg
https://www.audiophonics.fr/images2/6110/6110_BURSONDA160_2.jpg
Max sampling rate192kHz
ColorSilver
