DENAFRIPS TERMINATOR 15TH Balanced NOS R2R DAC Black
The Denafrips Terminator 15Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design, conceived to offer the best possible musical experience!
By buying this product you get 695 loyalty points
Reference : 19430
6 950,00 €tax incl.
5 791,67 € tax excl.
Shipping date: 18-07-2025.
Denafrips Terminator 15Th DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Black
Denafrips Terminator 15th : Vue de 3/4
Key features :
  • Low-noise power supply
  • High-precision OCXO clocks
  • Total insulation of digital and R2R modules
  • Adaptive FIFO buffer and reclocker
  • Support for DSD1024 and PCM 1536kHz streams via USB and I2S
  • Proprietary USB interface via STM32F446 microcontroller based on AMR technology
  • Pilote USB Thesycon
  • Dual AES/EBU input
  • Slow / sharp filters
  • I2S pinout configuration
  • I2S DSD configuration
Denafrips Terminator II 12th : Étage DAC
Denafrips Terminator 15Th: An exceptional DAC
The Denafrips Terminator digital/analog conversion module and its R2R ladder networks are perfectly isolated. The two boards are physically linked by the OCXO clock module. Physical isolation reduces background noise and improves the signal-to-noise ratio.
The Terminator II is equipped with two OCXO clocks operating at 45.1584MHz and 49.152MHz. Encapsulated in a metal housing located in the center of the DAC, these OCXOs are specially designed for high-end audio applications with ultra-low phase noise and very high precision. Both OCXOs are powered by the completely redesigned power supply circuit, providing constant current to the clocks. Adequate power reserves guarantee the linearity and stability of the clock signal.
Jitter is also reduced by reclocking the FIFO buffer. The adaptive FIFO buffer stores digital audio data. These are read directly using the ultra-low phase noise OCXO located directly in the DAC.
The Terminator also features an OCXO clock output for perfect synchronization of multiple audio devices.
Denafrips Terminator 15Th: An oversized power supply stage
The Denafrips Terminator 15Th incorporates its own linear power supply stage, located beneath the DAC board and separated from it by a steel partition to avoid any interference. The power supply itself uses two large O-Core toroidal transformers for the digital and analog sections, and low ESR capacitors to provide an electrical signal to all the audio circuits.
Denafrips Terminator 15Th: FPGA signal processing
To ensure the shortest possible signal path, I2S and SPDIF signals are processed by an FPGA chip, without any additional conversion chips.
Denafrips Terminator II 12TH : FPGA
Denafrips Terminator 15TH : Connectors
The Denafrips Terminator 15Th also boasts comprehensive connectivity, enabling easy integration into the vast majority of audio systems. Inputs include USB-B, I2S RJ45 LVCMOS, I2S RJ45 LVDS, I2S HDMI LVDS, AES/EBU, Toslink optical and coaxial. Outputs include unbalanced stereo RCA and balanced stereo XLR. Two clock outputs enable the Terminator and another audio device to be perfectly synchronized for optimum system performance.
Denafrips Terminator II 12TH : Connectique
1Balanced XLR output
2Single-ended RCA output
3 / 4Clock output
5Coaxial input
6Toslink optical input
7 / 8AES/EBU input
9I2S HDMI LVDS input
10 / 11I2S RJ45 LVDS / LVCMOS input
12USB-B input
13Power connector
Please note that the mains cable is not supplied.
Product typeNOS balanced R2R DAC
Inputs1x USB-B
1x I2S via HDMI LVDS
1x I2S via RJ45 LVDS
1x I2S via RJ45 LVCMOS
2x AES/EBU
1x Optical Toslink
1x Coaxial
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesUSB / I2S : PCM up to 1536kHz, DSD up to DSD1024
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Output level/impedanceRCA : 2.2Vrms @ 625Ω
XLR : 4.Vrms @ 1250Ω
Sampling modesNon-oversampling (NOS)
Oversampling (OS)
FiltersSlow
Sharp
Frequency response20Hz - 40kHz -0.2dB
THD+N0.002%
SNR120dB
Dynamic range> 132dB
Crosstalk-110dB
Supply oltage100-240VAC 50/60Hz
Consumption≤ 20W
Dimensions430 x 380 x 125mm
Weight19kg
Package1x Denafrips Terminator 15TH
InputI2S via RJ45
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
Remote ControlN/A
DENAFRIPS TERMINATOR 15TH DAC R2R NOS Balanced 24bit 1536kHz DSD1024 Black
The Denafrips Terminator 15Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an...
