Très bien, de belles basses, un son plein, une belle énergie.
AES / EBU Cable 2x0.25 mm² Ø7,20 mm
The SC-AQUA MARINEX MIKRO 25 cable by Sommer Cable is suitable for AES / EBU use as well as as microphone instrument cable.
Equipped with waterproof insulation, it is designed for use in a wet environment (sound system for swimming pools, boats, greenhouses, outdoors) and even supports permanent immersion up to 50 meters deep. This sealing is made possible by a double insulation made up of two braided screens in counter-opposition. While this gives the entire cable greater rigidity than traditional PVC cables, this insulation also provides mechanical protection against shocks, crushing or tearing of the cable.
SPECIFICATIONS | |||
Usage | Underwater / submerged Digital 110 Ω AES / EBU Stage / live | ||
Halogen-free / LSZH | Yes | ||
Colour | black | ||
Signal transmission | symmetrical | ||
Jacket material | PUR-SR | ||
Jacket Ø [mm] | 7,20 | ||
Number of Channels (audio) | 1 | ||
Inner conductor (audio) | 2 | ||
Inner conductor (audio) [mm²] | 0,25 | ||
AWG (audio) | 23 | ||
Shielding | 2 x copper spiral + special protective banding | ||
Shielding factor [%] | 95 | ||
Copper strands (audio) | 32 | ||
Copper strand Ø (audio) [mm] | 0,10 | ||
Conductor insulation material | PUR | ||
Conductor insulation Ø [mm] | 1,60 | ||
Weight per 1 m [g] | 65 | ||
UV-resistant | yes | ||
Fire load per m [kWh] | 0,27 | ||
Style variant | round | ||
Temperature min. [°C] | -40 | ||
Temperature max. [°C] | 80 | ||
Width [mm] | 7,2 | ||
Height [mm] | 7,2 | ||
Capac. cond./cond. per 1 m (audio) [pF] | 50 | ||
Capacity wire/wire at 1 ft. (audio) [pF] | 15,24 | ||
Capac. cond./shield. per 1 m (audio) [pF] | 190 | ||
Capacity wire/electic screen at 1 ft. (audio) [pF] | 57,912 | ||
Impedance [Ω] | 110 | ||
Insulation resist. per 1 km [GΩ] | 1 | ||
Insulation resist. per 1000 feet [GΩ] | 3,048 | ||
Insulation resist. per 1 km (audio) [GΩ] | 1 | ||
Insulation resist. per 1000 feet (audio) [GΩ] | 3,048 | ||
Conductor resistance per 1 km [Ω] | 78 | ||
Conductor resistance per 1000 ft. [Ω] | 237,744 | ||
BPVo-Euroclass | Fca |
Diameter (mm) | 7.2 |
Number of conductors | 2 |
Insulation material | Polyurethane (PUR) |
Shielding | Yes |
Section (mm²) | 0.25 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
