AUDIO-GD DI-24 Digital Interface
The Audio-GD DI-24 digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is designed to offer a plethora of options with regard to clock usage strategies: interfacing from the internal clocks, using an external clock (slave mode), or offloading the internal clock to a third-party device (master mode). This type of circuit allows integration into highly advanced audio systems.
By buying this product you get 68 loyalty points
Reference : 18711
689,00 €tax incl.
574,17 € tax excl.
Audio-GD DI-24 Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512 Black
Audio-GD DI-24 : Ftont view
An Altera FGPA logic circuit is responsible for generating the output signal. This high-frequency chip is isolated from the USB interface to avoid any parasitic noise, both in terms of signal conversion and clock signal accuracy.
Audio-GD DI-24 : New features
  • Integrated 50Ω and 75Ω external clock input ports.
  • Integrated 10MHz clock generator. The FPGA reduces jitter and phase noise. The 50Ω and 75Ω clock outputs enable operation as an external clock, feeding the DAC's 10MHz signal. The clock outputs can be switched between internal and external clock using front-panel buttons.
  • On-board isolator. USB and 10MHz clock input isolation.
  • All output circuits are powered by Class A power supplies for best analog feel. The USB interface, FPGA and clocks are powered by 4 groups of DC power supplies and 5 groups of ultra-fast linear power supplies.
Audio-GD DI-24 : Other features
  • Integrated regenerative power supply, designed using Class A power supplies and symmetrical Class A amplifiers.
  • The Amanero USB interface offers excellent compatibility and stability. It is compatible with Windows, OSX, iOS and Linux systems, and has been tested with certain models of Android TVs and smartphones.
  • The I2S HDMI output supports PCM and DSD formats. Sampling rate can be displayed on the front panel.
  • R-Core transformer and 13 groups of power supplies to power the various circuits independently.
  • The USB interface and FPGA processor use the same clocks to avoid affecting sound quality.
  • The FPGA's data processing mode can be parallel or serial.
  • The display can show PCM and DSD sampling rates, and can be used to view and select parameters.
  • Integrated USB firmware update button and FPGA firmware update connector.
Audio-GD DI-24 : I2S pinout
Audio-GD DI-24 : I2S pinout diagrams
Audio-GD DI-24 : Rear panel diagram
1Firmware update port and USB firmware reset button
2USB-B input
3Power input
4AES/EBU 110Ω output
575Ω coaxial output
675Ω 10MHz BNC output
750Ω 10MHz BNC output
8I2S HDMI LVDS output
975Ω 10MHz BNC input
1050Ω 10MHz BNC input
Product typeDigital interface
Inputs1x USB-B
1x Clock input 10MHz BNC 50Ω (0.3Vpp - 3Vpp)
1x Clock input 10Mhz BNC 75Ω (0.3Vpp - 3Vpp)
Outputs1x I2S HDMI LVDS 3.3V @ 100Ω
1x Coaxial 0.5Vp-p @ 75Ω
1x AES/EBU 5Vp-p @ 110Ω
1x Clock output 10MHz BNC, > 9dBm @ 50Ω
USB compatibilityWindows
OSX
Linux
ISO
Supported sampling ratesUSB / I2S : PCM up to 32bit 384kHz, DSD up to DSD512
AES/EBU / SPDIF : PCM up to 384kHz
Supply voltage220-240VAC 50/60Hz
Consumption17W
Dimensions (L x P x H)360 x 240 x 85mm
Weight3.5kg
Package1x Audio-GD DI-24
1x USB cable
1x Power cable
InputBNC
OutputI2S LVDS via HDMI
OutputBNC
OutputCoaxial SPDIF
OutputAES/EBU
Max sampling rate384kHz
Max sampling rateDSD512
Interface chipAmanero 384
AUDIO-GD DI-24 Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512 Black
The Audio-GD DI-24 digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is...
