DENAFRIPS IRIS 12TH Digital Interface DDC Black
Denafrips' very first USB digital-to-digital converter or digital interface (DDC), the Iris 12Th is the fruit of 3 years of research and development by the brand, taking advantage of its extensive know-how in DAC design and related technologies.
By buying this product you get 64 loyalty points
Reference : 18862
640,00 €tax incl.
533,33 € tax excl.
Shipping date: 25-06-2025.
Denafrips Iris 12Th Digital Interface DDC USB I2S SPDIF 32bit 384kHz DSD512 Black
Denafrips Iris 12th: Front view
This interface lets you extend the digital connectivity of your audio system or computer, while enhancing sound quality. What's more, the Iris works perfectly with a wide range of DAC brands and models on the market. The data stream of the incoming USB digital signal is stored by the FIFO buffer and then reclocked using the integrated femtosecond clock. This procedure considerably minimizes jitter, guaranteeing a signal free of digital noise. What's more, the Iris 12th benefits from galvanic isolation, protecting the signal from electrical interference and maintaining signal integrity throughout the conversion process.
The power supply stage of the Iris 12Th is also optimized to provide all circuits with a clean, stable electrical signal. These include a large 60VA UP-OCC copper O-Core transformer and 8 precision LDO voltage regulators.
Key features:
  • Proprietary FPGA DSP processing architecture
  • FIFO buffer and reclocking with integrated clock
  • TCXO oscillator
  • Optical isolation of all input interference
  • Proprietary USB audio solution via STM32F446 MCU based on AMR technology
  • Proprietary USB interface via STM32F446 microcontroller based on AMR technology
  • Pilote USB Thesycon
  • External clocks supported
  • UP-OCC 60VA O-Core copper transformer
Denafrips Iris 12th: Internal view
What is a DDC?
A DDC, or digital-to-digital converter, transforms a digital audio signal from one format to another. Its primary purpose is to facilitate interconnections between different audio devices.
In addition to this conversion, Denafrips Iris 12th uses advanced processing techniques to improve the sound quality of the output signal.
DDC operating diagram
Denafrips Iris 12TH: Connectors
The Denafrips Iris 12Th boasts comprehensive connectivity. While input is simply via a USB-B port, output includes I2S HDMI LVDS, I2S RJ45 LVCMOS, AES/EBU, Toslink optical and coaxial. The Iris 12Th also features BNC inputs for connecting an external clock.
Denafrips Iris 12TH : Connectique
1I2S HDMI LVDS output
2I2S RJ45 LVCMOS output
3AES/EBU output
4Optical Toslink output
5Coaxial output
649.152MHz clock input
745.1584MHz clock input
8USB-B input
9Power connector
Product typeDigital interface (DDC)
Inputs1x USB-B
External clock inputs 45.1548MHz / 49.152MHz
Outputs1x Coaxial
1x Optical Toslink
1x AES/EBU
1x I2S HDMI LVDS
1x I2S RJ45 LVCMOS
Supported sampling ratesUSB : PCM up to 768kHz, DSD up to DSD512
I2S : PCM up to 384kHz, DSD up to DSD512
Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supply voltage100-240VAC 50/60Hz (selectable)
Consumption≤ 20W
Dimensions220 x 250 x 62mm
Weight3.5kg
Package1x Denafrips Iris 12TH
OutputCoaxial SPDIF
OutputI2S via RJ45
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputI2S LVCMOS via RJ45
OutputOptical Toslink
Max sampling rate768kHz
Max sampling rateDSD512
Interface chipFPGA
Denafrips Iris 12
Highly recommended. If you ave a reasonably good system you will hear an improvement. Better definition pace and timiming / rythm
This review has been posted for DENAFRIPS IRIS 12TH Digital Interface DDC USB I2S SPDIF 32bit 384kHz DSD512 Black
Denafrips' very first USB digital-to-digital converter or digital interface (DDC), the Iris 12Th is the fruit of 3 years of research and...
