LHY AUDIO UBT-1 Digital Interface USB HDMI I2S SPDIF Bluetooth 5.1 32bit 384kHz DSD256
This LHY Audio UBT-1 digital interface lets you transmit a high-quality digital audio signal via your computer, tablet or smartphone to other digital audio devices. The UBT-1 digital interface features a USB-B connector input, a Bluetooth 5.1 receiver chip and several outputs: AES/EBU, SPDIF Coaxial, Optical Toslink, and HDMI-I2S.
Reference : 18475
299,00 €tax incl.
249,17 € tax excl.
LHY AUDIO UBT-1
LHY AUDIO UBT-1 Interface Numérique USB HDMI I2S SPDIF Bluetooth 5.1 32bit 384kHz DSD256
This LHY Audio UBT-1 digital interface lets you transmit a high-quality digital audio signal via your computer, tablet or smartphone to other digital audio devices. The UBT-1 digital interface features a USB-B connector input, a Bluetooth 5.1 receiver chip and several outputs: AES/EBU, SPDIF Coaxial, Optical Toslink, and HDMI-I2S. All powered by USB-C with accumulators for stable power supply and significantly reduced interference and noise. The AES/EBU and I2S outputs are independent and isolated for pure signal quality. This LHY Audio interface supports high-resolution streams up to PCM 32/bit 384kHz and native DSD up to DSD512. To top it all off, the front panel of the LHY Audio UBT-1 features numerous LED indicators, making for a pleasant user experience.
Bluetooth 5.1 reception with Qualcomm QCC5125 chip
A QCC5125 Bluetooth reception chip enables the UBT-1 to receive high-definition Bluetooth codecs; SBS, ACC, aptX, aptX LL, aptX HD and LDAC.
Amanero USB interface
A USB Amanero interface enables the LHY Audio UBT-1 to process the incoming digital signal and support high-resolution streams up to PCM 32bit 384kHz and native DSD up to DSD512.
If you need a driver to use USB, you can find them on the manufacturer's website: AMANERO drivers.
HDMI I2S LVDS output with DS90LV047A CMOS chip
An HDMI I2S output allows you to connect a device such as a DAC to I2S for a high quality sound signal. In fact, the LVDS electronic digital signal is used by HDMI I2S connections. This signal is highly immune to noise. The HDMI socket is set to the PS Audio standard.
LHY Audio UBT-1 overview
1AES/EBU ouput
2SPDIF Coaxial output
3Toslink optical output
4USB-B input
5HDMI I2S output
6Bluetooth antenna
7DC 5V USB-C power supply
Product typeDigital interface
USB interfaceAmanero
Bluetooth chipQualcomm QCC5125
Inputs1x USB-B
Bluetooth 5.1
Outputs1x AES/EBU
1x Optical Toslink
1x SPDIF Coaxial
1x HDMI I2S
Supported sample ratesHDMIS I2S: 32/Bit 384kHz, DSD256 (PSaudio)
USB to AES/EBU, SPDIF coaxial and Optical Toslink: 24bit 194kHz
Bluetooth to AES/EBU, SPDIF coaxial and Optical Toslink: 24bit 96kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Dimensions158x 135 x 48mm
Weight695g
Package1x Digital interface USB HDMI I2S SPDIF LHY UBT-1
1x Bluetooth antenna
1x USB-A to USB-B cable
1x USB-A to USB-C cable
1x Mains adapter US plug
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
Max sampling rateDSD256
Max sampling rate384kHz
Interface chipWM8805
Interface chipAmanero 384
This LHY Audio UBT-1 digital interface lets you transmit a high-quality digital audio signal via your computer, tablet or...
