TOPPING PROFESSIONAL E8X8 PRE Audio Interface
The E8x8 PRE audio interface from Topping Professional is an excellent device, designed for musicians and audio professionals. As usual, Topping offers a very high level of performance for perfectly transparent recording and playback of your audio tracks.
By buying this product you get 44 loyalty points
Reference : 20212
449,00 €tax incl.
374,17 € tax excl.
This product is temporarily unavailable.
Topping Professional E8x8 PRE USB Audio Interface 8 Inputs 8 Outputs 24bit 96kHz
Photo du TOPPING PROFESSIONAL E8x8 PRE
The comprehensive E8x8 PRE audio interface offers, as its name suggests, 8 analog inputs and 8 analog outputs, complemented by two USB ports, two headphone outputs and two optical outputs. The interface integrates 8 ultra-linear microphone preamplifier modules, two NFCA-LE headphone amplifiers and supports sampling rates up to 24bit 96kHz.
Les poinst forts du TOPPING PROFESSIONAL E8x8 PRE
Photo des preamp du TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE: ultra-linear microphone preamplifier modules
The Topping E8x8 PRE is equipped with eight ultra-linear microphone preamplifier modules developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E8x8 PRE can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Topping E8x8 PRE: Phantom power supply
Equipped with 48V phantom power and a switch to activate or deactivate phantom power for each of the four inputs, the Topping E8x8 PRE is perfectly compatible with condenser and dynamic microphones.
Alimentation fantôme du TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE: Low-noise voltage module
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unleashing the chip's full potential for high-purity audio transmission.
Module de tension faible bruit du TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE: two high-performance headphone amplifiers
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E8x8 PRE's NFCA-LE headphone amplifier modules enable the use of high-sensitivity headphones without distortion and noise.
The Topping E8x8 PRE offers two gain settings, high gain up to +17dBu and 2x580mW output power at 32Ω. The combination of this high gain and significant output power means that the Topping E8x8 PRE can easily accompany professional headphones with high impedance, up to 600Ω.
The E8x8 PRE is also equipped with two headphone outputs, each of which can be independently monitored and adjusted via the Topping Professional Control Center software and dedicated volume knobs.
Amplificateurs casque du TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE: zero-latency monitoring
The zero-latency design allows audio effects to be monitored in real time during recording or mixing, for improved productivity.
Monitoring zero latence
Plage dynamique et réglage du volume du TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE: analog volume control and wide dynamic range
The volume knobs on the line and headphone outputs use an analog potentiometer, offering excellent precision for easy sound level control. Line outputs have a dynamic range of 127dB, headphone outputs 132dB.
Topping E8x8 PRE: Independent mixers
Equipped with three 16-channel input mixers, the E8x8 PRE allows easy adjustment and control of audio effects. In addition, its 8 DAW channels and 6 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
Download Topping Professional Control CenterMixeurs indépendants
Topping E8x8 PRE: high-resolution audio
The Topping E8x8 PRE adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. This supports high-resolution audio streams for recording and playback, up to PCM 24bit 96kHz.
Furthermore, all four inputs are evenly mixed, enabling greater compatibility with mobile devices.
Interface XMOS du TOPPING PROFESSIONAL E8x8 PRE
Double port USB
Topping E8x8 PRE: Dual USB-C ports
The Topping E8x8 PRE uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E8x8 PRE is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
Topping E8x8 PRE: Two optical outputs
The E8x8 PRE's two Toslink optical outputs (SPDIF/ADAT) are capable of delivering up to 24bit 96kHz. The audio content to be output via the Toslink ports can be precisely selected to provide greater flexibility and interface extension scenarios.
Sorties optiques
Sortie d'horloge sur connecteur BNC
Topping E8x8 PRE: Independent clock output
The clock output on BNC connector allows multiple devices to be coupled by synchronizing the clock signal, thus reducing jitter and improving sound quality.
Topping E8x8 PRE: Aluminum chassis
The Topping E8x8 PRE's components are protected by a sturdy, durable aluminum-alloy chassis, sober and modern.
Le châssis en aluminium TOPPING PROFESSIONAL E8x8 PRE
Topping E8x8 PRE interface connectivity diagram
schéma de connectique de l'interface et dimensions
Topping Professional audio interface comparison
E1x2 OTGE2x2E4x4 PreE8x8 Pre
OTG interfaceYesNoNoNo
AlimentationUSB-CUSB-CUSB-CMain IEC
Interface typeUSB 2.0USB 2.0USB 2.0USB 2.0
MonitoringYes (adjustable mix ratio)Yes (adjustable mix ratio)Yes (adjustable mix ratio)Yes (adjustable mix ratio)
Input level indiucator1 set of LED2 set of LEDset of LED8 set of LED
Output level indicator2 set of LED2 set of LED4 set of LED8 set of LED
Mic preamp modulesUltra-linearUltra-linearUltra-linearUltra-linear
Headphone ampNFCA-LENFCA-LENFCA-LE2x NFCA-LE
Supported sample ratesUSB-C : PCM up to 24bit 192kHz
OTG : PCM up to 24bit 48kHz
PCM up to 24bit 192kHzPCM up to 24bit 192kHzPCM up to 24bit 96kHz
Control softwareYesYesYesYes
Supported OSMac, Windows, iOS, AndroidMac, Windows, iOS, AndroidMac, Windows, iOS, AndroidMac, Windows, iOS, Android
Power buttonYesYesYesYes
Weight415g530g830g1720kg
Mix channels43416
DAW channels8688
Loopback channels6466
Product typeUSB audio interface
USB protocolUSB 2.0
Mic inputs8x 8x XLR / 6.35mm jack combo connectors (with 48V phantom power switch)
Instrument inputs8x 8x XLR / 6.35mm jack combo connectors
Line inputs8x 8x XLR / 6.35mm jack combo connectors
Line outputs4x 6.35mm jack
Headphone outputs2x 6.35mm jack
Direct-zero-latence monitoringYes (with mix button)
Input vumetersYes (8x8 LED indicators)
Output vumetersYes (8x8 LED indicators)
Headphone amp moduleNFCA-LE
Supported sampling ratesPCM up to 24bit 96kHz
Control softwareYes (Topping Professional Control)
DAW channels8x
Loopback channels6x
Microphone input measurements (@ 24bit 96kHz)
Input noise-130.5dBu @ A-wt, 150Ω
THD+N-110dB (0.0003%) @ A-wt
Dynamic range115dB @ A-wt
SNR115dB
Crosstalk-140dB @ 1kHz
Frequency response20Hz - 40kHz (±0.2dB)
Max. input level8.6dBu
Input impedance1.5kΩ
Available gain58dB + 20dB (20db gain numérique)
Phantom power supply8x 48V on XLR connector
Line input measurements (@ 24bit 96kHz)
THD+N-107dB (0.00045%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.1dB)
Max input level23.9dBu
Input impedance9kΩ
Available gain58dB + 20dB (20db digital gain)
Connectors6.35mm jack TRS
Instrument input measurements (@ 24bit 96kHz)
THD+N-108dB (0.0004%) @ A-wt
SNR115dB
Frequency response20Hz - 40kHz (±0.3dB)
Max input level14.8dBu
Input impedance1MΩ
ConnectorsJack 6.35mm TS connector
Line output measurements (@ 24bit 96kHz)
THD+N-100dB (0.001%) @ A-wt
Analog dynamic range127dB @ A-wt, -40dB attenuation
SNR115dB @ A-wt
Crosstalk-128dB @ 1kHz
Max input level14dBu
Noise1.8uVrms @ A-wt
Output impedance100Ω
ConnectorsBalanced 6.35mm TRS jack connectors
Headphone output measurements (@ 24bit 96kHz)
Analog dynamic range132dB @ A-wt, -40dB attenuation
SNR115dB @ A-wt
Crosstalk-120dB @ 1kHz
Max. input level0dBu @ Gain = L
17dBu @ Gain = H
Noise1uVrms @ A-wt
Output impedance1Ω
Connectors6.35mm TRS stereo jack
Headphone output power2x580W @ 32Ω, THD+N < 1%
2x380W @ 64Ω, THD+N < 1%
2x198W @ 150Ω, THD+N < 1%
2x105W @ 300Ω, THD+N < 1%
2x55W @ 600Ω, THD+N < 1%
Power supply100-240V AC 50Hz/60Hz
Dimensions43 x 17.5 x 5.3cm (without rack mounting holes)
48.5 x 17.5 x 5.3cm (with rack mounting holes)
Weight1720g
Package1x Topping Professionnal E8x8 PRE
1x Power cable
1x USB-A to USB-C cable
1x USB-C cable
1x Jack 6.35mm to Jack 3.5mm adapter
InputXLR
InputJack 6.35mm
OutputJack 6.35mm
Max sampling rate96kHz
Interface chipXMOS XU308
TOPPING PROFESSIONAL E8X8 PRE USB Audio Interface 8 Inputs 8 Outputs 24bit 96kHz
The E8x8 PRE audio interface from Topping Professional is an excellent device, designed for musicians and audio professionals. As usual, Topping...
