By buying this product you get 44 loyalty points
The E8x8 PRE audio interface from Topping Professional is an excellent device, designed for musicians and audio professionals. As usual, Topping offers a very high level of performance for perfectly transparent recording and playback of your audio tracks.
The comprehensive E8x8 PRE audio interface offers, as its name suggests, 8 analog inputs and 8 analog outputs, complemented by two USB ports, two headphone outputs and two optical outputs. The interface integrates 8 ultra-linear microphone preamplifier modules, two NFCA-LE headphone amplifiers and supports sampling rates up to 24bit 96kHz.
The Topping E8x8 PRE is equipped with eight ultra-linear microphone preamplifier modules developed by the brand, with an input noise of just -130.5dBu. Even at its maximum volume level, the E8x8 PRE can maintain a very low noise floor, ensuring that every detail of your recording is perfectly captured. This ultra-linear architecture ensures that the audio signal is transmitted with sufficient precision for a perfectly clear and transparent recording.
Equipped with 48V phantom power and a switch to activate or deactivate phantom power for each of the four inputs, the Topping E8x8 PRE is perfectly compatible with condenser and dynamic microphones.
Topping's unique LNRD module provides a stable reference power level for the AD/DA converter chip, unleashing the chip's full potential for high-purity audio transmission.
With a noise floor of just 0.9uVrms and an output impedance of 1Ω, the Topping E8x8 PRE's NFCA-LE headphone amplifier modules enable the use of high-sensitivity headphones without distortion and noise.
The Topping E8x8 PRE offers two gain settings, high gain up to +17dBu and 2x580mW output power at 32Ω. The combination of this high gain and significant output power means that the Topping E8x8 PRE can easily accompany professional headphones with high impedance, up to 600Ω.
The E8x8 PRE is also equipped with two headphone outputs, each of which can be independently monitored and adjusted via the Topping Professional Control Center software and dedicated volume knobs.
The zero-latency design allows audio effects to be monitored in real time during recording or mixing, for improved productivity.
The volume knobs on the line and headphone outputs use an analog potentiometer, offering excellent precision for easy sound level control. Line outputs have a dynamic range of 127dB, headphone outputs 132dB.
Equipped with three 16-channel input mixers, the E8x8 PRE allows easy adjustment and control of audio effects. In addition, its 8 DAW channels and 6 LoopBack channels are designed to adapt to different recording, mixing and playback needs.
Download Topping Professional Control CenterThe Topping E8x8 PRE adopts an excellent USB XMOS interface, compatible with Windows, Mac, iOS and Android operating systems in particular. This supports high-resolution audio streams for recording and playback, up to PCM 24bit 96kHz.
Furthermore, all four inputs are evenly mixed, enabling greater compatibility with mobile devices.
The Topping E8x8 PRE uses USB-C connectivity for data transmission and power supply. We recommend connecting the auxiliary power connector if the E8x8 PRE is used in conjunction with a desktop computer, or if 48V phantom power is required, to avoid interference. An external power supply is also recommended when the sound card is used with a smartphone.
The E8x8 PRE's two Toslink optical outputs (SPDIF/ADAT) are capable of delivering up to 24bit 96kHz. The audio content to be output via the Toslink ports can be precisely selected to provide greater flexibility and interface extension scenarios.
The clock output on BNC connector allows multiple devices to be coupled by synchronizing the clock signal, thus reducing jitter and improving sound quality.
The Topping E8x8 PRE's components are protected by a sturdy, durable aluminum-alloy chassis, sober and modern.
E1x2 OTG | E2x2 | E4x4 Pre | E8x8 Pre | |
OTG interface | Yes | No | No | No |
Alimentation | USB-C | USB-C | USB-C | Main IEC |
Interface type | USB 2.0 | USB 2.0 | USB 2.0 | USB 2.0 |
Monitoring | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) | Yes (adjustable mix ratio) |
Input level indiucator | 1 set of LED | 2 set of LED | 4 set of LED | 8 set of LED |
Output level indicator | 2 set of LED | 2 set of LED | 4 set of LED | 8 set of LED |
Mic preamp modules | Ultra-linear | Ultra-linear | Ultra-linear | Ultra-linear |
Headphone amp | NFCA-LE | NFCA-LE | NFCA-LE | 2x NFCA-LE |
Supported sample rates | USB-C : PCM up to 24bit 192kHz OTG : PCM up to 24bit 48kHz | PCM up to 24bit 192kHz | PCM up to 24bit 192kHz | PCM up to 24bit 96kHz |
Control software | Yes | Yes | Yes | Yes |
Supported OS | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android | Mac, Windows, iOS, Android |
Power button | Yes | Yes | Yes | Yes |
Weight | 415g | 530g | 830g | 1720kg |
Mix channels | 4 | 3 | 4 | 16 |
DAW channels | 8 | 6 | 8 | 8 |
Loopback channels | 6 | 4 | 6 | 6 |
Product type | USB audio interface |
USB protocol | USB 2.0 |
Mic inputs | 8x 8x XLR / 6.35mm jack combo connectors (with 48V phantom power switch) |
Instrument inputs | 8x 8x XLR / 6.35mm jack combo connectors |
Line inputs | 8x 8x XLR / 6.35mm jack combo connectors |
Line outputs | 4x 6.35mm jack |
Headphone outputs | 2x 6.35mm jack |
Direct-zero-latence monitoring | Yes (with mix button) |
Input vumeters | Yes (8x8 LED indicators) |
Output vumeters | Yes (8x8 LED indicators) |
Headphone amp module | NFCA-LE |
Supported sampling rates | PCM up to 24bit 96kHz |
Control software | Yes (Topping Professional Control) |
DAW channels | 8x |
Loopback channels | 6x |
Microphone input measurements (@ 24bit 96kHz) | |
Input noise | -130.5dBu @ A-wt, 150Ω |
THD+N | -110dB (0.0003%) @ A-wt |
Dynamic range | 115dB @ A-wt |
SNR | 115dB |
Crosstalk | -140dB @ 1kHz |
Frequency response | 20Hz - 40kHz (±0.2dB) |
Max. input level | 8.6dBu |
Input impedance | 1.5kΩ |
Available gain | 58dB + 20dB (20db gain numérique) |
Phantom power supply | 8x 48V on XLR connector |
Line input measurements (@ 24bit 96kHz) | |
THD+N | -107dB (0.00045%) @ A-wt |
SNR | 115dB |
Frequency response | 20Hz - 40kHz (±0.1dB) |
Max input level | 23.9dBu |
Input impedance | 9kΩ |
Available gain | 58dB + 20dB (20db digital gain) |
Connectors | 6.35mm jack TRS |
Instrument input measurements (@ 24bit 96kHz) | |
THD+N | -108dB (0.0004%) @ A-wt |
SNR | 115dB |
Frequency response | 20Hz - 40kHz (±0.3dB) |
Max input level | 14.8dBu |
Input impedance | 1MΩ |
Connectors | Jack 6.35mm TS connector |
Line output measurements (@ 24bit 96kHz) | |
THD+N | -100dB (0.001%) @ A-wt |
Analog dynamic range | 127dB @ A-wt, -40dB attenuation |
SNR | 115dB @ A-wt |
Crosstalk | -128dB @ 1kHz |
Max input level | 14dBu |
Noise | 1.8uVrms @ A-wt |
Output impedance | 100Ω |
Connectors | Balanced 6.35mm TRS jack connectors |
Headphone output measurements (@ 24bit 96kHz) | |
Analog dynamic range | 132dB @ A-wt, -40dB attenuation |
Crosstalk | -120dB @ 1kHz |
Max. input level | 0dBu @ Gain = L 17dBu @ Gain = H |
Noise | 1uVrms @ A-wt |
Output impedance | 1Ω |
Connectors | 6.35mm TRS stereo jack |
Headphone output power | 2x580W @ 32Ω, THD+N < 1% 2x380W @ 64Ω, THD+N < 1% 2x198W @ 150Ω, THD+N < 1% 2x105W @ 300Ω, THD+N < 1% 2x55W @ 600Ω, THD+N < 1% |
Power supply | 100-240V AC 50Hz/60Hz |
Dimensions | 43 x 17.5 x 5.3cm (without rack mounting holes) 48.5 x 17.5 x 5.3cm (with rack mounting holes) |
Weight | 1720g |
Color | Black |
Package | 1x Topping Professionnal E8x8 PRE 1x Power cable 1x USB-A to USB-C cable 1x USB-C cable 1x Jack 6.35mm to Jack 3.5mm adapter |
Input | XLR |
Input | Jack 6.35mm |
Output | Jack 6.35mm |
Output | XLR |
Max sampling rate | 96kHz |
Color | Black |
Interface chip | XMOS XU308 |
