TOPPING PROFESSIONAL M62 Portable USB Audio Interface Black
Topping Professional unveils a portable USB audio interface offering a wide range of uses. High-performance, it offers 88dB microphone gain, 118dB DNR in ADC and 122dB in DAC, as well as up to 2x 500mW into 32 ohms of headphone output power. It also offers a range of features such as AI noise reduction, an equalizer, auto gain, ducking, and even reverb.
Reference : 21130
249,00 €tax incl.
207,50 € tax excl.
Last items in stock !
Shipping date: 10-03-2026.
Topping Professional M62 Portable USB Audio Interface Bluetooth 4 Inputs 1 Output 24-bit 96 kHz Black
Photo de l'interface TOPPING PROFESSIONAL M62
 unveils a portable USB audio interface offering a wide range of uses. High-performance, it offers 88dB microphone gain, 118dB DNR in ADC and 122dB in DAC, as well as up to 2x 500mW into 32 ohms of headphone output power. It also offers a range of features such as AI noise reduction, an equalizer, auto gain, ducking, and even reverb. The M62 interface has three operating modes: mobile mode, book stream mode, and pro audio mode. In terms of connectivity, it is well equipped with two USB-C ports, including one OTG, three microphone inputs, a 3.5mm AUX jack input, and a 3.5mm headphone jack output. Added to this is Bluetooth functionality with support for aptX Low Latency and aptX HD high-definition codecs. The whole thing is powered by a 5000mAh battery offering up to 8.5 hours of battery life.
Les avantages de l'interface M62
Topping Professional M62: A high-resolution experience
The M62 audio interface is compatible with most operating systems, including Android, iOS, Windows, and macOS. The ASIO driver supports up to 24bit 96kHz PCM, enabling high-resolution recording. It also provides up to 16 recording tracks. Whether for vocal or instrumental recording, the M62 allows you to record or stream live in a professional way.
Enregistrement haute résolution
Conversion haute performance
Topping Professional M62: High-performance AD/DA conversion
Thanks to its superior analog circuit design, the M62 allows its DAC and ADC chips to be used to their full potential. This interface therefore provides a wide dynamic range and detailed rendering.
Input DNR (ADC)Output DNR (DAC)
118dB122dB
ADC THD+NDAC THD+N
< -116db (0.00015%)< -115db (0.00017%)
Topping Professional M62: Ultralinear Preamplifier Module
The M62 is equipped with a proprietary preamplifier module offering excellent performance. It provides clear sound reproduction, free from background noise, allowing you to capture every detail. The 88dB gain makes it easy to drive the iconic Shure SM7B microphone, for example.
Module préamplificateur du M62
Topping Professional M62: Numerous features
Réduction de bruit
Noise reduction
Built-in AI noise reduction ensures clear and accurate voices in complex environments.
Reverb professionnelle
Professional reverb
Three reverb modes are available (Studio, Live, and Hall) to suit every stage..
Gain auto
Auto gain
This intelligently optimizes your microphone's gain so that it can be used to its full potential.
Canardage Audio
Audio Ducking
This feature removes background noise, music, or ambient sounds to make voices clearer and put dialogue front and center.
Égaliseur d'entrée
Input equalizer
The equalizer allows you to calibrate the sound before it enters the recording device, whether it's vocals or instruments. And it does so with zero latency, in real time. This feature greatly reduces the need for post-production processing, whether for podcasts, live singing, or streaming.
Égaliseur de sortie
Output equalizer
It is also possible to customize the audio output before it reaches the headphone output. This EQ offers the possibility to optimize the soundstage for a balanced and immersive overall output. It is therefore possible to adapt the output to various uses: music listening, gaming, movies, etc.
Topping Professional M62: 5000mAh battery
The built-in 5000mAh battery provides 6.5 to 8.5 hours of battery life on a single charge, depending on the configuration.
  • 8.5 hours without a condenser microphone.
  • 6.5 hours with two condenser microphones.
Batterie du M62
Topping Professional M62: 3 operating modes
Mode mobile
Mobile mode
This mode does not require any additional software. Works directly for your best live sessions.
Mode streaming live
Live streaming mode
Intelligent processing instantly optimizes live streaming rendering.
Mode audio Pro
Pro Audio Mode
Designed specifically for creators, record in high-resolution 24-bit 96kHz PCM.
Topping Professional M62: Mix Control Software
The Control M Center software provides a 5-band, 20-channel mixer that can handle up to 10 DAW inputs and 8 return signals.
Logiciel de contrôle de mix
Topping Professional M62: Multiple inputs for backing tracks
It is easy to use a backing track via Bluetooth or the AUX input. Bluetooth supports SBC, AAC, aptX Low-Latency, and aptX HD codecs.
Les entrées piste du M62
La sortie casque du M62
Topping Professional M62: Powerful headphone output
The headphone amplifier delivers up to 2x 500W into 32 ohms (THD+N<1%) via its 3.5mm jack output. Its high gain combined with its +16dBu output level and ultra-low output impedance of 1 ohm makes it easy to drive professional headphones with high impedance up to 600 ohms.
Topping Professional M62: Remote control
The M62 interface remote control works via Bluetooth and IR and allows you to quickly and easily adjust the volume and effects, particularly for live performances and streaming.
La télécommande du M62
Overview of the Topping Professional M62 portable audio interface
Aperçu de l'interface Topping Professional M62
1Microphone inputs (2x 6.35mm jack / 1x 3.5mm jack)
23.5mm AUX jack input
33.5mm headphone jack output
4USB-C OTG output volume control
5Headphone output volume control
6Noise reduction switch
7Switch reverb
8Reverb amount control
9Input volume control
10Input selection
11USB-C charging port
12USB-C OTG port
13USB-C port
14ON/OFF button
Product typePortable USB audio interface
Inputs2x 6.35mm TRS jack inputs (with 48V phantom power)
3.5mm TS/TRRS microphone input (with 2.5V bias voltage)
Bluetooth
Outputs1x 3.5mm jack headphone output
Other connectors1x USB-C OTG port
1x USB-C port
Supported sample ratesUSB-C OTG: 16bit 48kHz / 24bit 48kHz
USB-C: 24bit 44.1kHz / 24bit 96kHz
DAW channels10
Recording channels16
Loopback channels8
Operating modesMobile mode
Live streaming mode
Pro audio mode
Compatible operating systemsWindows / OSX / iOS / Android
Mixers5
EQ4 bands per microphone input
EQ type: parametric
10-band EQ on headphone output (only in Pro Audio mode)
DuckingDucking for all channels
Adjustable parameters: threshold, attack, reduction, release
Noise reductionAI noise reduction, noise gate
70 levels available for each mode
Reverb3 types of reverb
Adjustable parameters: Dry/Wet mix, Room size, Decay
Input level indicatorIN1, IN2, AUX, BT avec LED RGB
Output level indicatorsHP and OT with 2x9 double multicolor LED bars
IN1 input selection indicatorsMIC 1, Mic-3.5, Mic-HP with 3 white LEDs
Noise reduction indicatorNC1, NC2 with two white LEDs
Ducking indicatorWith 1 white LEDs
Reverb selection indicatorStudio, Live, Hall with 3 white LEDs
48V phantom power indicator for Mic1 and Mic22 red LEDs
Power and battery indicatorsLED circle
Microphone input
Equivalent input noise-129.5dBu
THD+N @ A-WT-116dB (0.00015%)
Dynamic range @ A-WT118dB
SNR @ A-WT118dB
Crosstalk @ 1kHz-140dB
Frequency response20Hz-20kHz (+/-0.2dB)
Max. input level8.6dBu
Input impedance2.0kOhms
Available gain0-88dB
Phantom power supply48V
Connector typeJack 6.35mm TRS
AUX input
THD+N @ A-WT-110dB (0.0003%)
Dynamic range @ A-WT117dB
SNR @ A-WT117dB
Crosstalk @ 1kHz-118dB
Max. input level2.6dBu
Input impedance10kOhms
Available gain-99dB +9.5dB
Connector typeJack 3.5mm TRS
3.5mm MIC jack input
THD+N @ A-WT-100dB (0.001%)
Dynamic range @ A-WT113dB
SNR @ A-WT113dB
Max. input level4dBu
Input impedance1.2kOhms
Bias voltage2.5V
Connector typeJack 3.5mm TS
3.5mm MIC-HP jack input
SNR @ A-WT113dB
Bias voltage2.5V
Connector typeJack 3.5mm TRRS
THD+N @ A-WT-115dB (0.00017%)
Dynamic range @ A-WT122dB
SNR @ A-WT122dB
Crosstalk @ 1kHz-130dB
Max. output level16dBu
Bruit @ A-WT3.8uVrms
Output impedance1 Ohms
Output power2x 500mW @ 32 ohms (THD+N<1%)
2x 330mW @ 64 ohms (THD+N<1%)
2x 150mW @ 150 ohms (THD+N<1%)
2x 80mW @ 300 ohms (THD+N<1%)
2x 39mW @ 600 ohms (THD+N<1%)
USB OTG output (@OTG 24-bit 48 kHz & USB-C 24-bit 44.1/96 kHz)
THD+N @ A-WT-130dB (0.00003%)
Dynamic range @ A-WT138dB
SNR @ A-WT138dB
Crosstalk @ 1kHz-154dB
Frequency response20Hz-20kHz (+/-0.1dB)
Max. output level-0.5dBFS
Connector typeUSB-C OTG
Power supply5V 1-2.5A via USB-C
Battery5000mAh
Charging time< 2.5 hours (with AC adapter > 10W, device turned off)
Autonomy> 8.5 hours (without condenser microphone connected)
> 7.5 hours (with one condenser microphone connected)
> 6.5 hours (with two condenser microphones connected)
Dimensions7.2 x 15 x 2cm
Weight300g
Package1x Topping Professional M62
1x Remote Control
1x USB-A to USB-C Cable
1x USB-C Cable
InputJack 3.5mm
InputJack 6.35mm
OutputJack 3.5mm
OutputUSB
Max sampling rate96kHz
Interface chipNC
TOPPING PROFESSIONAL M62 Portable USB Audio Interface Bluetooth 4 Inputs 1 Output 24bit 96kHz Black
Topping Professional unveils a portable USB audio interface offering a wide range of uses. High-performance, it offers 88dB microphone gain, 118dB...
