Converter Optical SPDIF to USB
The UR23 is a converter allowing to recover an optical SPDIF signal (on 3.5mm connector) to convert it and then output it to USB-A. It works in USB Audio Class 1, compatible with sampling rates up to PCM 24bit 96kHz and this without driver installation. It is thus compatible with Windows, Mac and Linux systems.
Suitable for transferring DAT tapes, minidiscs or other digital sources to audio files on your computer. Please note that it cannot be connected directly to a USB device such as a DAC, it must be connected to a USB host such as a computer.
Product type | Optical SPDIF to USB converter |
Input | Optical SPDIF 3.5mm |
Output | USB-A |
Supported sampling rate | PCM up to 24bit 96kHz |
Dimensions | 5.5 x 3.5 x 1.8cm |
Weight | 30g |
Color | Black |
Package | 1x UR23 Converter |
