By buying this product you get 89 loyalty points
DSP Correction Acoustique Stéréo
The interaction between the speakers and the listening room is usually the main factor limiting the performance of any high-end audio system. Each listening space introduces errors that can be on the order of ten decibels or more. These errors are generally most pronounced in the low frequency and low midrange regions, where conventional acoustic processing loses its effectiveness.
The DSPeaker Anti-Mode 2.0 Dual Core is an award-winning speaker optimization system capable of improving the acoustic performance of any full-range stereo audio system. It is based on the company's Anti-Mode 2.0 algorithm. The DSP measures the acoustics of the room and automatically corrects for defects in the room's acoustics to provide improved sound reproduction.
1 | IR Receiver |
2 | TFT Screen |
3 | Microphone input |
4 | Balanced XLR input |
5 | Balanced XLR output |
6 | Single-ended RCA input |
7 | Single-ended RCA output |
8 | 12VDC Power connector |
9 | Mini USB input |
10 | Optical Toslink input |
11 | Optical Toslink output |
12 | DataLink Connector |
Product type | Room correction DSP |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA 1x Optical Toslink 1x Mini USB 1x Jack 3.5mm microphone input |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA 1x Optical Toslink |
Functions / Filters | FIR / IIR Filter curve Linear Phase Tilt Parametric EQs Adjustable infrasonic Adjustable low-pass or high-pass |
Dynamic range | > 108dB |
Volume control steps | 0.5dB |
Input senstivity | XLR : 3.9/7.9Vrms RCA : 2.5/5.0Vrms |
Output voltage | XLR : 14.4Vrms max RCA : 7.2Vrms max |
ADC | 6.144MHz oversampling dual per channel |
DAC | 6.144MHz oversampling dual per channel, local clocking, buffering |
Supply voltage | 12VDC |
Dimensions (L*P*H) | 236*153*55mm |
Color | Black |
Package | 1* DSPeaker Anti-Mode 2.0 Dual Core 1* Measurement microphone 1* Remote control 1* Power supply |
Input | RCA |
Input | Optical |
Input | USB |
Input | XLR |
Output | XLR |
Output | RCA |
Output | Optical Toslink |
Max sampling rate | NC |
Color | Black |
