By buying this product you get 119 loyalty points
Processor 7.1 Analog balanced Dirac Series
The Dirac DDRC-88A fits between your analog source and your preamplifier or integrated amplifier.
It has been designed to radically transform your listening and allow you to rediscover your audio installation.
MiniDSP and Dirac Live search brings you here a solution of acoustic treatment and digital correction with this unique hardware / software combination.
The processor incorporates a sophisticated digital processing algorithm that intelligently corrects for frequency and time errors caused not only by the listening room, but by the people themselves.
The result is an improved stereo image, more clarity and realism, a more accurate timbre and a deeper bass.
Here is the product you need. Correct the acoustics of your listening room with an easy-to-use interface.
The case consists of a high-resolution audio processor.
So you get great results.
Based on measurements alone, I was borderline on recommending the DDRC-88A. But the software pushed me over the line, making it a joy to program the thing to build a discrete 7.1 system or two active speakers. Sadly, you can't do better than a good AVR or AV Processor although it does give you Dirac EQ and very nice set of programmable EQ.
This product is compatible with our remote control
Technical characteristics : Processor: 32bits
Input / output resolution: 24bits
Internal sampling frequency: 48kHz
Analog Inputs: 8x Asymmetric RCA, 8x Symmetrical Analog Outputs: 8x Asymmetrical RCA, 8x Symmetrical
Comes with 12V 3.3A AC adapter
Included: 1 license for Dirac Calibration Tool, 1 power supply.
Compatibility: Microsoft Windows Vista SP1 / XP Pro SP2 / Win7 / Win8 Intel Pentium III min., AMD Athlon XP (SSE needed), 2GB of RAM
| Input | Screw terminals |
| Input | RCA |
| Output | Coaxial SPDIF |
| Output | AES/EBU |
| Output | RCA |
| Output | Screw terminals |
| Output | Optical Toslink |
| Max sampling rate | 48kHz |
| Color | Black |
