MINIDSP SHD STUDIO Digital Signal Processor DSP SHARC ADSP21486 Dirac Live Volumio Streamer
MiniDSP's Studio SHD (Streaming High Definition) is a Digital Audio Processor (DSP) that includes the Dirac Live acoustic correction solution. A solution that can be adapted to all systems, since it offers a complete range of connectivity and network connectivity.
4.7 / 5
By buying this product you get 109 loyalty points
Reference : 13582
1 099,00 €tax incl.
915,83 € tax excl.
MiniDSP SHD Studio neo3
Processeur Audio Numérique DSP SHARC ADSP21486 Dirac Live Lecteur Réseau Volumio
MiniDSP's Studio SHD (Streaming High Definition) is a Digital Audio Processor (DSP) that includes the Dirac Live acoustic correction solution. A solution that can be adapted to all systems, since it offers a complete range of connectivity and network connectivity. This means that AES/EBU, Coaxial SPDIF, Toslink Optics and USB are at the input. For outputs, Studio SHD offers SPDIF and AES/EBU on 4 channels.
This great versatility is complemented by the ability of Studio SHD to function as a network drive thanks to its Ethernet port and Quad-Core ARM processor. It integrates the Volumio operating system, which will allow you to easily access files stored on your network or on a local USB device, from Internet radios or via Spotify.
For the calibration of your audio system, the device uses a UMIK-1 microphone (sold separately and essential) and the Dirac Live calibration tool, both powerful and easy to use. The latter includes a 10-band parametric equalizer per channel, a 48dB/octave crossover, a compressor/limiter, and a 2x4 mixing matrix.
Review by The Hans Beekhuyzen Channel
Product typeDSP
DSP ChipAnalog Devices SHARC ADSP21486 / 450MHz, 32bit, floating point
Internal sampling rate96kHz
ControlUSB 2.0 Interface for Windows
A computer is only required for initial configuration and USB audio streaming
ProcessorARM Quad Core
Streamer OSVolumio
USBAsynchronous XMOS
Sampling rate : 192kHz
Bi-directionnal audio : 2 channel playback (PC to SHD) / 4 channel Post-processing recording (SHD to PC)
InputsAES/EBU XLR 3 pins (isolated with digital audio transformer)
Coaxial SPDIF (isolated with digital audio transformer)
Optical Toslink
Outputs2x Coaxial SPDIF (isolated with digital audio transformer)
2x AES/EBU
Headphone amplifier chipCS43130
DSP TreatmentVolume, Parametric equalizer, Crossover, Matrix mixer, Compressor/Limiter, Mute
Filters storageUp to 4 filters
CompatibilityWindows 10/11
Mac OS 10.14 or later
Power supply12V DC (included)
Dimensions214.5 x 206 x 41.5mm
Package1x MiniDSP SHD Studio with Dirac Live licence
1x IR Remote
1x Power cable
InputXLR
InputRJ45
OutputCoaxial SPDIF
Max sampling rate192kHz
7 reviews
Maj volumio shd studio
Je reviens sur mon avis concernant le lecteur reseau volumio intégré, avec une bonne alimentation le streamer devient tout a fais écoutable, dans mon cas j'y ai mis une batterie de 12v de voiture pour supprimer toute pollution secteur, la différence est casi inaudible vs mon streamer lumin u1 mini+ sbooster, je vais d'ailleurs surement le revendre ...
This review has been posted for MINIDSP SHD STUDIO Digital Signal Processor DSP SHARC ADSP21486 Dirac Live Volumio Streamer
Indispensable
Apres avoir esseyer un open drc que l'on ma prêté, sur mon system a pavillon lecleach 53cm+ compression bms 4590 et grave de 38cm, j'ai pu expérimenter le traitement numerique pour lineariser la courbe de réponses et la phase de mon system, les résultats étaient deja exception a l'écoute, pour finir mon système avec un filtrage full numerique grave - pavillon je me suis lancé sur le shd studio avec dirac live, ce que je fesais avec rew et rephase en 1h30 (et pas parfaitement) le shd le génère de facon completement linéaire (vérifiée a la mesure) en moin de 15sec. Le tout en aes ebu diy , c'est démentiel et extrêmement efficace. A l'écoute tout prend sa place comme il se doit, les applaudissements sur les live devienne réel et ne sont plus des crépitement disgracieux. Les timbre des instruments sont respectées a la perfection, on entre vraiment dans une autre dimension d'écoute. Il sera impossible pour moi d'écouter sans mon shd. J'ai donc 2 dac, un pour la voie grave et 1 pour le medium aigu (compression coaxial avec filtre passif) on fais vraiment ce qu'on veux avec chaque registre. Je l'utilise avec un micro calibré ecm8000 behringer sans probleme. La courbe mesuré sur rew est plate et tient dans 2db de 35 a 20khz. La partie streamer volumio n'est pas exceptionnel et bien moin bon que mon lumin u1 mini twerké, mais pour 1000e on a quand meme un streamer qui fonctionne bien.
Indispensable
Après avoir hésité, j'ai acheté le micro de mesures UMIK-1 et j'ai testé Dirac live en direct sur le site de l'éditeur avec Audirvana. Le choix était soit Dirac live (environ 350 €) avec audirvana ou le SHD studio avec son lecteur Volumio intégré !! J'ai choisi le lecteur car j'ai le choix des entrées et plusieurs sorties. Au final, dans mon bureau ou je suis installé de manière assymétrique (pas le choix à cause des portes fenêtres et radiateur), j'ai un son d'une qualité exceptionnelle, je n'ai plus les ronflements dus aux modes (ondes stationnaires), la musique respire, le son est équilibré, je peux écouter plus fort et quelle que soit la musique, je prends du plaisir. Je redécouvre mes albums et qobuz !! Arrêtez d'acheter du matériel hors de prix et commencez par nettoyer le son, vous entendrez la différence !! Croyez-moi, le retour arrière est impossible !!
 (3)
MiniDSP SHD et DiracLive transforment l'écoute
J'utilise Dirac Live 3.0.9 avec MiniDSP SHD studio pour corriger des "trous" dans les basses fréquences bien visibles avec REW et liés à la pièce. Je voulais rester en tout numérique jusqu'au DAC de mon ampli.
Ces problèmes ont bien été corrigés: les graves sont plus "ouverts" et une mesure avec REW confirme la correction.
Un autre effet positif est que chaque instrument est mieux séparé des autres. J'imagine que c'est du à la correction temporelle spécifique à Dirac Live. Cela rend un scène de Jazz vraiment plus présente.
Pour la mise en oeuvre:
- J'utilise le micro UMIK-1 pointé vers le plafond avec son fichier 90° de callibration
- J'utilise la connexion USB de mon Mac après avoir configuré le data rate depuis Audio MIDI Setup
- J'ai fait les mesures avec des distances entre 2 positions de micros de l'ordre de 40 cm
- J'ai configuré le filtre de Dirac Live jusqu'à 300Hz pour laisser les aigus sans correction (je n'ai pas vraiment vu de différence en allant sur tout le spectre, mais le niveau de sortie est plus élevé ainsi)
REZ semble indiqué que les corrections sont les plus efficaces pour la position la plus rapprochée (chair), puis (sofa). La position intermédiaire donne les moins bon résultats dans mon cas.
A noter:
* Le passage de standby à ON depuis la télécommande prend quelques secondes (avec un écran noir durant le démarrage)
* Dans sa newsletter d'OCtobre, MiniDSP annonce un support prochain de Roon. En fait cela fonctionne déjà, mais sans contrôle de volume depuis Roon, comme non certifié à ce jour
What a difference
I tried several streamers and i was not satisfied. When I bought the MiniDSP SHD Studio and connected it to my DAC, Wow, out of the box, without calibration it left me speechless.
The sound much fuller (as the saying got meat on the bones), no sharpness, everything sounds far better.
But the star is the DIRAC, when I did the calibration, wow again, I didn't know my system could sound like this.
I listen to different genres of music, Jazz, Rock, Indie, Electronic and some Classic.
For example, Lindsy Starling in 88.2 / 24 format, as if I was in concert now. Whatever i play, it just sounds so much better.
I must say that Hans Beekhuyzen is absolutely right, magnificent.
The only thing I do not use is factory power supply, but I specifically bought the IFI AUDIO IPOWER X Low Noise Switched Mode Power Supply 12V to eliminate the noise of cheap factory power supply at first.
All in all Thank you Audiophonics, for your fast delivery at such a weird time.
stay well, stay healthy
MiniDSP's Studio SHD (Streaming High Definition) is a Digital Audio Processor (DSP) that includes the Dirac Live acoustic correction solution....
