EIZZ EZ-4003-800 Input Selector 3 Positions Ø6mm Smooth Cylindrical Shaft
This EIZZ EZ-4003-800 3-position source selector offers absolutely exceptional design quality. Under its CNC machined aluminium body, which gives it great robustness, a strong design and limits interference, there are hidden gold-plated copper contacts ensuring excellent conductivity.
Reference : 13140
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 20-05-2025.
EIZZ EZ-4003-800
Input selector 3 positions Ø 6mm Smooth Cylincrical Shaft
EIZZ EZ-3003-800 Potentiomètre commuté 3 positions Ø 6mm Axe Lisse
This EZ-4003-800 input selector from EIZZ offers absolutely exceptional design quality. Underneath its CNC machined Aluminium body, which gives it great robustness, a strong design and limits interference, there are hidden Gold Plated Copper contacts ensuring excellent conductivity. In addition, each pin is associated with a letter, allowing easy locating for easier blending. Once installed on your device, it will allow you to enjoy a clean switch. Its smooth brass shaft has a diameter of 6mm, allowing you to install the compatible button of your choice.
Button sold separately.
Connection diagram
Potentiomètre Eizz EZ-3003-800 schéma de connexion
Number of positions3 positions
Shaft materialBrass
Contacts materialGold plated Copper
Body materialAluminium alloy
Max panel thickness3.9mm
Max diameter38mm
Total height47mm
Shaft diameter6mm
Shaft length10.4mm
8 reviews
Superbe
Un produit remarquable de très bonne facture ..la mise en œuvre très facile ..un rapport qualité prix incroyable.
This review has been posted for EIZZ EZ-4003-800 Input Selector 3 Positions Ø6mm Smooth Cylindrical Shaft
Nice selector.
Sélecteur de Source
Produit conforme à la description (4 contacts / 3 positions)
Fonctionne bien,
Rien à redire à part un axe un peu court mais ça ne pose pas de problème avec le bouton que j ai choisi :
(https://www.audiophonics.fr/fr/boutons-volume-6mm/bouton-aluminium-axe-meplat-38x25mm-o6mm-argent-p-11812.html)
Très satisfait
Le sélecteur livré est bien un EZ-4003 et non 3003, ce qui signifie qu'il est tel que décrit mais avec une voie de plus, donc c'est bien 3 positions mais 4 contacts et non 3, ce qui est mieux donc on ne va pas se plaindre ! Concernant la qualité c'est impeccable, une vraie sensation de haut de gamme et décidément cette marque me surprend toujours par son rapport qualité/prix.
Livré en kit
C'est pas chère mais c'est pas terrible, le sélecteur est arrivé sans la vis ressort bille qui Bloque la rotation de l'axe, en plus il y a du jeu dans l'axe donc, pas terrible comme produit.
This EIZZ EZ-4003-800 3-position source selector offers absolutely exceptional design quality. Under its CNC machined aluminium body, which gives...
