This Ethernet switch has 8 RJ45 connectors allows you to connect several devices to your local network at once. These RJ45 ports have the 100/1000Base-TX standard. An optical fiber connector is also available with 100/1000Base-FX standard. This allows you to take advantage of the flexibility of the RJ45 connection, but also of the stability and signal transmission speed of optical fibre, while at the same time allowing you to have a longer transmission distance. The switch part is managed by a high-performance Marvell 88E6097 chip.
Adaptateur secteur 5VDC 1A via Jack DC 5.5/2.5mm vendu séparément.
Product type | Switch converter Optical fiber / Ethernet |
Cache memory | 96Kb |
Interface | 8x Ethernet RJ45 Ports 100/1000Base-TX 1x SC Optical fiber1000/Base-FX |
Dimensions | 125 x 120 x 38mm |
Color | Black |
Case material | Metal |
Length (m) | N/A |
Shielding | NC |
Section (mm²) | N/A |
Connector | Optical |
Connector | RJ45 |
Conductors material (Cable) | Optical Fiber |
Conductors Plating (Cable) | NC |
