By buying this product you get 28 loyalty points
The Viborg LAN8 RJ45 Ethernet cable is a high-end Ethernet cable with an exceptional design. This cable features 99.998% pure solid silver conductors. It also features double shielding with metallic foil and silver-plated copper braid, as well as PTFE insulation. It has been cryogenically treated at -196°C. The cable also features CAT8 network connectors with gold-plated contacts on both sides. The VIBORG LAN8 features a maximum frequency of 2000MHz and a bandwidth of up to 40Gbps.
1 | Pure solid silver |
2 | PTFE insulation (Teflon) |
3 | Metal foil shielding |
4 | Silver-plated copper braid shielding |
5 | PE sheath |
6 | Braided nylon + PPS |
Product type | RJ45 ethernet cable |
Connectors | 2x RJ45 |
Conductors material | Pure solid silver (99.998%) |
Insulation | PTFE |
Shielding | Metal foil + silver-plated copper braid |
External sheath | PE (Polyéthylène) |
Covering sheath | Nylon + PPS |
Length | 2m |
Package | 1x Viborg LAN8 RJ45 ethernet cable |
Length (m) | 2.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RJ45 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
