Qualité Avérée
No featrued products
This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very good conductivity and therefore an excellent quality of signal transmission. This connector is able to accommodate cables up to 15mm in diameter and is thus suitable for both "classic" cables and HiFi cables with a larger diameter. The connector body is made of PC 94V-0 and TPR. All the screws of this connector are made of stainless steel 304, preventing corrosion.
| Specifications | |
| Connector type | IEC C13 |
| Contact material | Copper alloy |
| Contact plating | Gold 24k |
| Max. cable diameter | Ø15mm without sleeve Ø12mm with sleeve |
| Voltage / Current | 250V AC / 15A |
| Dimensions | 108*22mm |
| Weight | 42g |
| Screws | Phillips screws Materrial: Stainless steel 304 |
| Color | Black |
| Max cable diameter (mm) | 15.0 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | IEC C13 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
| Rated current (A) | 15.0 |
Average votes 4.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Sandy Clémence B.
Julien G.
