TRN BT30 Pro are Bluetooth receivers for IEM earphones with 0.78mm CIEM connectors. These Bluetooth receivers are based on a Qualcomm QCC3040 chip as well as their own amplification thanks to a MAX97220A chip. As a result, they support AAC, SBC and aptX codecs for the most reliable and stable wireless transmission, while delivering a power output of over 42mW under 16ohm. Added to this is Qualcomm CVC 8.0 noise cancellation technology for optimized rendering and clear voices during your phone calls. Their battery offers up to 6.5 hours of use on a 1.5-hour charge. As for the charging capacity of the box, it offers up to 1200mAh of charging capacity for a total of 32h of use of the Bluetooth receivers with it. In terms of ergonomics and comfort, TRN Bluetooth receivers offer a secure fit for earphones, and are covered with a water- and sun-resistant nano-coating for extended outdoor life.
TRN BT30 Pro Bluetooth receivers are based on a Qualcomm QCC3040 chip and a MAX97220A amplifier chip. This chipset provides power and support for high-fidelity Bluetooth codecs, with a noise level of just under 9uV and an SNR of 98dB. Bluetooth 5.2 offers a range of up to 15m and support for high-definition SBC, AAC and aptX codecs.
The BT30 Pro's internal microphone incorporates Qualcomm's cVc 8.0 noise reduction for optimized rendering and clear communication during phone calls.
TRN BT30 Pro are made from a flexible thermoplastic elastomer that makes wearing your favorite IEM comfortable. In addition, a nano-layer protects them from water and perspiration for use in all circumstances.
Product type | Bluetooth receiver for IEM |
Bluetooth chip | QCC3040 |
Headphone amplification | MAX97220A |
Connectors | CIEM 0.78mm |
Bluetooth version | 5.2 |
Supported Bluetooth codecs | SBC, AAC, aptX |
Output power | 42mW @ 16 ohm |
Bluetooth range | 15m |
Charging | 5V 2A via USB-C (Charging box) |
Load capacity | Box: 1200mAh Bluetooth receiver: 80mAh/piece |
Standby autonomy | 180h |
Time of use | 50h with box 13h with bluetooth modules only |
Charging time | Modules: 1.5h Box: 2.5h Wireless charging: 3.5h |
Weight | 8g per module |
Package | 1x Pair of TRN BT30 PRO Bluetooth modules 1x Charging/storage box |
Input | Bluetooth |
Output | CIEM 0.78 |
DAC / ADC Chip | NC |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | SBC |
