By buying this product you get 319 loyalty points
HYPSOS V2 HiFi Power Supply + OOR Preamplifier Headphone Amplifier + FPL Cable
The Ferrum Hypsos V2 power supply and the Ferrum OOR preamplifier/headphone amplifier combo have been designed primarily to work together. They form a perfect duo in order to take advantage of a high quality preamplification and amplification, thanks to an optimized electrical signal. This pack is therefore ideal to enjoy a system with excellent sound reproduction. In addition, the Ferrum FPL cable ensures a perfect connection between the two devices thanks to its proprietary Ferrum Power Link technology.
Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the essence of your music. With very low distortion, impressive dynamics and an incredible level of detail, the OOR is the ultimate companion for headphone listening.
The Ferrum Hypsos V2 is a high-end power supply, offering exceptional technology and performance to give your HiFi system an extremely clean power supply for optimal sound reproduction. It has features that are unheard of in this price range. The device is software controlled, with as few hardware dependent elements as possible.
The Ferrum FPL cable connects the Hypsos power supply to the OOR preamplifier/headphone amplifier to take advantage of Ferrum's proprietary Power Link (FPL) technology. This technology allows for a perfectly stable and clean transmission of the power supply to promote a very pure sound.
Ferrum OOR Specifications | |
Product type | Headphone amplifier Preamplifier |
Inputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA 1x Balanced XLR 4 pins headphone output 1x Single-ended Jack 6.35mm headphone output |
Gain | Balanced : -4dB, +6dB, +16dB Single-ended : -10dB, 0dB, +10dB |
Frequency response | 20Hz - 100kHz 0.1dB |
Output powre | Balanced : 1600mW @ 300Ω, 8W @ 60Ω Single-ended : 400mW @ 300Ω, 2W @ 60Ω |
Input impedance | 94kΩ |
Output impedance | Balanced : 44Ω (pre-out) Single-ended : 22Ω (pre-out) |
Headphone output impedance | < 0.3Ω |
Supply voltage | 22-30VDC |
Consumption | < 15W |
Housing marterial | Aluminum |
Color | Black |
Dimensions | 21.7 x 20.6 x 5cm |
Weight | 1.8kg |
Ferrum Hypsos V2 Specifications | |
Product type | HiFi power supply |
Input supply voltage | 110-240VAC / 50-60Hz |
Input connector | IEC C14 With fuse, power button and two-stage EMI filter |
Output cables | 1x Jack DC 5.5/2.5mm 50cm 1x Jack DC 5.5/2.1mm 50cm |
Output voltage range | 5-30V adjustable |
Courant de sortie continu max | 6A |
Puissance de sortie continue max | 60W |
Primary winding fuse | IEC 5x20mm fuse, 250V 3.15A |
Dimensions | 217 x 206 x 50mm |
Weight | 3.05kg |
Color | Black |
Housing material | Aluminum |
Ferrum FPL Specifications | |
Product type | Power cable |
Number of conductors | 4 |
Contacts plating | Gold |
Length | 50cm |
