MATRIX CUBE USB DAC SPDIF 24/192 - BNC - RCA - Headphones
By buying this product you get 23 loyalty points
Reference : 5528
239,00 €tax incl.
199,17 € tax excl.
MATRIX CUBE - USB DAC SPDIF 24/192 - BNC - RCA - Headphones
DAC with USB inputs - BNC (SPDIF), OPTICAL (SPDIF), coaxial output SPDIF
Input / Output RCA / Headphone Amplifier.
This device is a Digital - Analog Converter and Headphone Amplifier.
Despite its compact size it is equipped with many digital inputs, input analog outputs, and a headphone amplifier.
Its great technical versatility allows multiple configurations:
  • DAC directly connected in USB to your computer, to get the most out of your audio files.
  • Amplifier Headphone with volume control
  • Output Line-Out with fixed volume
  • A switch allows you to choose the source of the headphone section either the stereo analog input (MP3, Ipod ...) or the internal DAC.
  • Digital pass-trough for a DTS or AC3 signal arriving in optics and requiring external decoding by a DTS decoder.
It incorporates the Jitter Reduction Asynchronous Sample Rate Converter (ASRC).
https://www.audiophonics.fr/images2/5528/5528_MATRIX_CUBE_1.jpg
https://www.audiophonics.fr/images2/5528/5528_MATRIX_CUBE_3.jpg
https://www.audiophonics.fr/images2/5528/5528_MATRIX_CUBE_4.jpg
https://www.audiophonics.fr/images2/5528/5528_MATRIX_CUBE_2.jpg
Download the manual in English
Features:/ Span>
  • Diagram 100% symmetrical
  • Decoding chips WOLFSON WM8740
  • Up to 24Bit / 192kHz
  • Integrated headphone amplifier, up to 300 ohms
  • RCA quality audio outputs
  • Simple DAC (without volume control)
  • Output Headphone and analog simultaneously (two amplifier circuits)
Digital Inputs:
  • Toslink optics from 44.1 to 192kHz
  • Coaxial: 75ohm RCA or BNC (supplied adapter) from 44.1 to 192kHz
  • USB: 44.1 or 48kHz USB-B connector (PC only)
Digital Outputs:
  • SPDIF Coaxial
  • 44 to 192kHz according to input
  • Allows even redirecting an AC3 or DTS stream
Analog Outputs:
  • RCA: 0 ~ 2V variable volume
  • Frequency response: 20Hz - 20kHz
  • Signal to noise ratio: 112dB
  • Dynamic range: 107dB
  • Distortion: 0.0002% @ 1kHz
Analog Input:
Others:
  • Weight: 1.1kg
  • Dimensions: 205x155x44mm
  • Power Consumption: 15W
  • Comes with: Power cable, USB cable, BNC adapter -> RCA
InputBNC
OutputCoaxial SPDIF
DAC / ADC ChipWM8740
Max sampling rate192kHz
ColorSilver
