SILKLINE T8 Tuner Radio FM / DAB / DAB+
The Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB + digital radio, which is more recent and above all offers a much better quality of reproduction.
4.5 / 5
Reference : 17687
189,00 €tax incl.
157,50 € tax excl.
SILKLINE tonemax T8
SILKLINE TONEMAX T8 Tuner FM / DAB / DAB+
The Silkline Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB+ digital radio, which is more recent and above all offers a much better quality of reproduction.
Simple, efficient and elegant, it will easily fit into your Hi-Fi installation. Moreover it has a station recording function allowing you to easily find up to 30 different bands whether in FM or DAB. It also has a screen displaying key information thanks to the RDS decoder (PTY, PS and text info) and a remote control.
It is equipped with a stereo RCA output as well as a Toslink optical output that you can pair with an external DAC. Reception for DAB reaches 384Kpbs which is much better than MP3 or CD audio quality standard.
Finally, its performance in terms of audio output sampling quality reaches PCM 48KHz thanks to its JRC5532 AOPs.
Product typeTuner FM / DAB / DAB+
Reception typeDSP Digital high speed
Redio station memory30 FM stations
30 DAB stations
RDS decoder(PTY, PS  Text)
Inputs1* stereo RCA
1* Optical Toslink
ScreenOLED
Remote control
Antenna
FM reception frequency87.5MHz - 108MHz
DAB reception frequency174.5Mhz - 240MHz
Nominal output level500mV
Reception sensibilityFM: -106dB
DAB: -99db
SNRFM: 50dB
DAB: 72dB
Wave distorsionFM: <0,03%
DAB: <0,03%
Channel separationFM: 50dB
DAB: 72dB
Power supplyAC 220V
Dimensions430*200*44mm
Weight3kg
Package1x Silkline Tonemax T8
1x Remote control
1x Power cable
1x FM/DAB antenna
InputDAB+
InputDAB
InputFM
OutputOptical Toslink
DAC / ADC ChipNC
Max sampling rate48kHz
2 reviews
H B
Tuner de très bonne facture son de qualité mais la télécommande reçue avec n'est pas celle de la photo, il n'y a que 9 touches, et sur le mode d'emploi, la télécommande est bien celle de la photo, je recommande ce tuner.
This review has been posted for SILKLINE T8 Tuner Radio FM / DAB / DAB+
je ne lis pas le chinois mais apres de longues minutes j'ai reussi a programmer la telecommande bon achat le son est parfait manques notice en francais
The Tonemax T8 is an FM / DAB / DAB+ tuner equipped with an RDS decoder that allows you to broadcast analog FM radio as well as DAB + digital...
