AUDIOPHONICS PSU250 Switched Mode Power Supply 220V AC to 48V 5A DC 250W
This AC adapter supports 176-264V AC input and supplies 48V DC 5A (250W) via its GX16 connector output. The AC adapter's components are housed in a robust aluminum chassis for efficient heat dissipation.
Reference : 18648
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 20-05-2025.
Photo of Power Adapter 176-264V AC to 48V 5A DC Audiophonics
This AC adapter supports 176-264V AC input and supplies 48V DC 5A (250W) via its GX16 connector output. The AC adapter's components are housed in a robust aluminum chassis for efficient heat dissipation. Specifically, inside the chassis is an MP-H250S48 switch-mode power supply module with PFC (Power Factor Correction) directly mounted on a heat sink for heat dissipation. The circuit also incorporates protection against overcurrent, overvoltage, thermal overshoot and short-circuit. AC input is via an IEC C14 connector and output via a GX16 connector.
Product typeSwitched mode power supply
Chassis materialAluminum
InputIEC C14
Output1x GX16
Input voltage176-264V AC 50/60Hz
Output voltage48V DC 5A
Power250W
Precision of voltage stability±1%
Dimensions102 x 208 x 50mm
Net weight1.1kg
Package1x Audiophonics power adapter
1x Standard IEC C13 to Schuko male power cable
1x Power cable GX16 to multiple DC jack 5.5/2.5mm and 5.5/2.1mm
InputIEC C14
OutputGX16
Output voltage (V)48.0
Output current (A)5.0
Input voltage (V)260.0
Input voltage (V)190.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)180.0
Input voltage (V)230.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Power SupplySMPS
This AC adapter supports 176-264V AC input and supplies 48V DC 5A (250W) via its GX16 connector output. The AC adapter's components are housed...
