Section (mm²)
0 mm - 6 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Marc S.
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la...
Johan v.
Good after software update
Not bought here for practical reasons it would not read anything after track 31 and after a helpful email from Shanling and a...
Johan v.
My favorite hookup wire
Strips easely soldering well heat resistant great to work with
Hook-up Wires
Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Mono conductor
    Mono conductor
    Here you will find all of our single conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
  • Multi conductors
    Multi conductors
    Here you can find all our multi-conductor cabling wires, sold by the metre, for the internal wiring of your appliances and DIY projects.
