Refurbished product - Grade S
Brand new product. First version
Connector IEC C13 UP-OCC Copper Rhodium Plated Ø24mm
This IEC C13 Neotech NC-P303R IEC C13 connector will allow you to design your own high performance power cables. It incorporates 99.99999% pure UP-OCC copper contacts with rhodium plating, ensuring optimum conductivity and oxidation resistance. Assembly is simply done via a screw system, without the need for soldering. The connector is delivered with reducers to effectively hold your cable.
Product type | IEC C13 connector |
Contacts material | UP-OCC Copper |
Contacts plating | Rhodium |
Max cable diameter (without reducer) | Ø24mm |
Diameters with reducers | Ø17mm Ø14mm Ø11mm |
Max conductors section | 3.31mm² (12AWG) |
Mounting type | To screw |
Total dimensions | Ø43 x 84mm |
Max cable diameter (mm) | 24.0 |
Connectic | Female |
Connector | IEC C13 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Rated current (A) | N/A |
Refurbished Grade | Grade S |
