DAYTON AUDIO D1075T Horn Speaker Driver 78W with 70V Transformer
The Dayton Audio D1057T is a horn speaker driver featuring robust materials and design. It is a model recognised by installers and audio professionals. It uses a phenol-impregnated cloth diaphragm to provide a clean, articulate sound. A cast aluminium front panel, plastic rear housing with gasket and stainless steel parts ensure long-term reliability for both indoor and outdoor use.
Reference : 17997
49,90 €tax incl.
41,58 € tax excl.
Last items in stock !
Shipping date: 13-05-2025.
Dayton Audio D1075T
Dayton Audio D1075T Horn Speaker Driver 78W with 70V Transformer
The D1057T has a response that lends itself perfectly to sound reinforcement or PA systems, thanks to its effectiveness in the frequency range of human voices and the midrange detail of stringed instruments. Its impedance curve is also easily manageable for simple, versatile system design.
This model is also completely ready to use. With its built-in 70V transformer, the selectable sockets allow you to customise the output of each speaker to suit a multitude of locations and circumstances. Use the high-level sockets for high vaulted ceilings or wherever you need a high sound pressure level. Lower level sockets are available for installations requiring lower sound pressure levels.
Product typeHorn speaker driver with transformer
Handling power75W
Frequency response180Hz - 6000Hz
SPL110dB 1W/1m
Exit diameter25.4mm (1")
Diaphragm materialKapton / Polyimide
Mounting type1-3/8" - 18 TPI standard thread
Transformer voltage70V
Transformer taps25W
30W
50W
75W
Bypass 16Ω
DimensionsØ139.7*152.4mm
Speaker Power (W RMS)75.0
Speaker TypeHorn loudspeaker
Impedance (Ω)NC
Loudspeaker diameter (mm)143.0
Diaphragm typeFabric
Efficiency / Sensitivity (dB)110
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)180
Highest frequency (Hz)6000
The Dayton Audio D1057T is a horn speaker driver featuring robust materials and design. It is a model recognised by installers and audio...
