| Medium to High Pavilion With 3.5 cm (1 3/8 ") thread, made of PVC. For compression chamber motor Piezo. |
| Speakers Speakers | ||
| Bandwidth | 800-20000 Hz | |
| Max. | ||
| Max. Permissible load | ||
| system 4 Ω | ||
| system 8 Ω | ||
| Pressure sound. (2,83V / 1m) | ||
| Angle dispersion (vert./hor.) | 30 ° / 60 ° | |
| Impedance / 1kHz | - | |
| cutting | 232x85 mm | |
| Mounting depth | 165 mm | |
| Dimensions | 265 x 111 mm | |
| Weight | 350 g |
| Speaker Power (W RMS) | NC |
| Speaker Type | Horn loudspeaker |
| Impedance (Ω) | NC |
| Loudspeaker diameter (mm) | N/A |
| Diaphragm type | N/A |
| Efficiency / Sensitivity (dB) | N/A |
| Max Linear Excursion (Xmax) (mm) | N/A |
| Lowest frequency (Hz) | 800 |
| Highest frequency (Hz) | 20000 |
