No featrued products
Power Filter EMI/RFI 230V 10A
This IEC C14 socket is ideal for integration into a HiFi device. It integrates a mains filter to provide your devices with a clean power supply, promoting high quality audio reproduction. The base has a rated current of 10A and a leakage current of less than 0.5mA.
| Specifications | |
| Product type | Filtered IEC socket |
| Current | 10A |
| Leakage current | ≤ 0.5mA |
| Nominal voltage | 125/250VAC |
| Operating frequency | 50/60Hz |
| Operating temperature | -25°C / +85°C |
| Standard | UL 1283 CSA 22.2 No. 8 1986 IEC/EN 60939 |
| Total dimensions | 50.1 x 22.2 x 55.5mm |
| Mouting holes spacing | 40mm |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male |
| Connector | IEC C14 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | None |
| Rated current (A) | 10.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
