7HZ AURORA In-Ear Monitors
New
With the Aurora, 7Hz presents in-ear monitors incorporating four drivers to provide effective coverage of the entire frequency band. 7Hz uses dynamic, balanced armature and planar magnetic driver technologies to effectively cover the frequency range, assigning each technology the area in which it excels best. As a result, the dynamic driver is in charge of low frequencies, the balanced armature drivers are assigned to the midrange, and the planar magnetic driver is dedicated to high frequencies.
By buying this product you get 42 loyalty points
Reference : 20583
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 08-05-2025.
7Hz Aurora In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 30 Ohm 105dB 5Hz-40kHz
7HZ Aurora : Front view
7Hz Aurora: Ø12mm dynamic driver
The Ø12mm composite diaphragm driver features a dual voice coil system that dramatically enhances low frequencies and delivers reduced distortion. Specifically tuned to cover the lower end of the frequency range effectively, this driver delivers a well-textured, powerful bass for an impactful result.
7HZ Aurora with cable
7Hz Aurora : Dual balanced armature drivers
In order to cover the midrange frequency range effectively, Aurora uses a balanced armature driver duo, providing the bridge between the dynamic driver and the planar magnetic driver.
7Hz Aurora : 6mm planar magnetic driver
For treble reproduction, the Aurora incorporates a Ø6mm planar magnetic driver. Thanks to meticulous airflow management, 7HZ gets the very best out of this driver, enabling its earphones to reproduce the finest detail while extending high frequencies up to 40kHz.
7HZ Aurora with supplied ear tips
7HZ Aurora with cable and detachable termination
7Hz Aurora : 3-way crossover
The Auroras have been carefully tuned using a three-way passive crossover network to exploit the full potential of each driver. The tuning offers a powerful bass presence that transitions smoothly to slightly warm, natural midrange. The highs are clear and detailed, but also kept below 10dB to provide a comfortable and refined listening experience.
7Hz Aurora: Unique aesthetics
The Aurora shell has been carefully crafted using professional 3D printing with medical grade UV resin. This creates a high-precision shell that is skin-friendly, comfortable and durable. What's more, the front plates are made from titanium filaments that create a unique pattern on each piece.
7HZ Aurora on their box
7HZ Aurora on a telephone
7Hz Aurora : Single-crystal copper cable
The Aurora is supplied with a detachable 0.78mm 2pin CIEM gold-plated monocrystalline copper cable. The cable has an interchangeable 3.5mm/4.4mm modular plug system to adapt to all your devices.
Review of the 7Hz Aurora by Headfonics
"The 7Hz Aurora is a competitive new tribrid contender in the $400 segment. The 6mm micro planar driver for the treble region delivers good detail and resolution, with strong and impactful sub-bass tonality from its 12mm dynamic driver."
Logo Headfonics
Product typeÉcouteurs intra-auriculaires
Drivers1x Dynamic driver Ø12mm
2x Balanced armature driver
1x Planar magnetic driver Ø6mm
Frequency response5Hz-40kHz
Impedance30Ω
Sensitivity105dB/V @ 1kHz
Earphone connectorsCIEM 0.78mm 2 pins
Cable conductor materialGold-plated copper
Cable terminationJack 3.5mm
Jack 4.4mm
ColorSilver
Blue
Package1x 7Hz Aurora
1x CIEM cable
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Carrying bag
6x Pairs of ear tips
ColorSilver
ColorBlue
Impedance (Ω)30
Efficiency / Sensitivity (dB)105.0
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
7HZ AURORA In-Ear Monitors IEM Dynamic Balanced Armature Planar Magnetic 30 Ohm 105dB 5Hz-40kHz
With the Aurora, 7Hz presents in-ear monitors incorporating four drivers to provide effective coverage of the entire frequency band. 7Hz uses...
