EARACOUSTICS SPA PRO In-Ear Monitors
New
EarAcoustic's SPA-PRO are in-ear earphones based on a dynamic driver with a dual N52 magnetic circuit and an ultra-thin, rigid graphene membrane, enabling fast transient response across a wide frequency range for consistent, dynamic and detailed reproduction across the entire frequency band. This results in neutral sound reproduction designed to cause little listening fatigue, making these earphones ideal for professional use or critical listening.
Reference : 21005
87,90 €tax incl.
73,25 € tax excl.
Shipping date: 02-09-2025.
EarAcoustic SPA-PRO Dynamic In-Ear Monitors IEM 16 Ohm 113dB 5Hz-40kHz
EarAcoustic SPA-PRO : Front view
EarAcoustic
EarAcoustic SPA-PRO: Graphene diaphragm dynamic driver
SPA-PRO speakers feature a dynamic driver equipped with a dual N52 neodymium magnetic circuit, offering high magnetic flux density for better control of the diaphragm movement and a more linear response, even at high volumes.
The graphene diaphragm, which is both ultra-thin and very rigid, significantly reduces distortion while improving the driver's responsiveness. This combination provides excellent transient response and accurate reproduction across the entire audible spectrum, from deep bass to extended treble.
EarAcoustic SPA-PRO : Cutaway view of the driver
EarAcoustic SPA-PRO : Acoustic simulation of the internal cavity
EarAcoustic SPA-PRO: Acoustic simulation of the internal cavity
The internal cavity of SPA-PRO has been rigorously designed and tested (listening, modelling, measurements) to optimise sound wave management.
The objective was to effectively guide the acoustic flow while avoiding internal reflections and unwanted resonances. The volume, geometry, and materials used were adjusted to achieve a clean response, free of colouration, with a stable and well-defined sound stage.
EarAcoustic SPA-PRO: Balanced sound signature
Designed for demanding audiophiles and sound professionals alike, the acoustic profile of the SPA-PRO is based on neutrality and transparency. The frequency response is linear, with no excess in the bass or excessive brightness in the treble. This approach preserves signal integrity while ensuring fatigue-free listening, even during long sessions. The result is a natural, balanced sound that is ideal for mixing, production or critical listening.
EarAcoustic SPA-PRO : frequency response
EarAcoustic SPA-PRO: Silver-plated OFC copper cable
SPA-PROs come with a 3.5mm jack to 0.78mm 2-pin silver-plated OFC copper cable, guaranteeing high-quality signal transmission without external interference.
EarAcoustic SPA-PRO connected to their cables
Product typeIn-ear earphones
DriverØ11.4mm dynamic driver
Impedance16Ω
Sensitivity113dB
Total harmonic distortion (THD)< 0.5%
Frequency response5Hz-40kHz
CableDetachable
Earphone connectors0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSilver-plated OFC copper
ColorSilver
Package1x EarAcoustic SPA-PRO
1x 3.5mm jack to 0.78mm 2-pin cable
1x Carrying bag
6x Pairs of ear tips
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)113
WirelessNo
Phone call featureNo
Noise reductionNo
EARACOUSTICS SPA PRO Dynamic In-Ear Monitors IEM 16 Ohm 113dB 5Hz-40kHz
EarAcoustic's SPA-PRO are in-ear earphones based on a dynamic driver with a dual N52 magnetic circuit and an ultra-thin, rigid graphene...
