LETSHUOER EJ07M Dynamic IEM In-Ear Headphones Hybrid Electrostatic Membrane 19 Ohm 107dB 20Hz-30kHz
LETSHUOER EJ07M headphones are designed for professional use. It is particularly suitable for stage performances and studio mixing by meeting the high demands of the environment.
By buying this product you get 59 loyalty points
Reference : 17592
599,00 €tax incl.
499,17 € tax excl.
LETSHUOER EJ07M
Dynamic IEM In-Ear Headphones Hybrid Electrostatic Membrane 19 Ohm 107dB 20Hz-30kHz LETSHUOER EJ07M Dynamic IEM In-Ear Headphones Hybrid Electrostatic Membrane 19 Ohm 107dB 20Hz-30kHz
They carry two IEM hybrid drivers with advanced electrostatic technology. Indeed, four sonion EST65QB02 speakers and two sonion 2389 symmetrical armature bass-midrange speakers are present in these headphones. In addition, there is a dynamic speaker in each of them with a 10mm monocarbon membrane. It is this tribride association with 7 drivers that allows a sound transcription with very low distortion, superb highs as well as a precise and fast response. In general, the transcribed sound is rather soft and very detailed.
Whether you are a singer, DJ, musicians, audiophile, or studio professional, these headphones will suit you.
Passive noise rejection and confort
The EJ07M are housed in a sound cavity made of an aluminum alloy found in the aeronautical industry. This brings them two advantages, they block up to 26dB of ambient noise and remain comfortable over long sessions of use.
High purity OCC Copper cable
The EJ07M in-ear headphones are equipped with a high-purity OCC copper monocrystalline cable featuring a braided structure that also helps reduce noise and makes the cable strong while being lightweight and flexible. In terms of connectors, this model has standard 2 pin 0.78mm connectors and a balanced 4.4mm jack.
A shell with an exceptional design
The LETSHUOER team, in addition to integrating a high-quality 316L stainless steel shell on the design of the EJ07M, has also affixed a front panel with a unique look with a carbon fiber faceplate and gold flakes. More generally, the ergonomic shape makes them comfortable to use.
Type of productIn-Ear Monitors (IEM)
Type of driversSonion squad EST65QB02
Sonion 2389
10mm Monocarbon Nanotube Dynamic Driver
Headphone connectors
0.78mm 2PIN
Cable connectorJack 4.4mm
Frequency response20Hz - 30kHz
Impedance19Ω
Sensitivity107dB/mW
DIstorsion0.5%
Cable material OCC Pure copper
Cable length1.25m
ColorBlack graphite
Package1x In-ear headphones (IEM)
1x Storage metal case
1x 0.78mm 2 Pin cable
1x 4.4mm balanced Jack
6x pairs of silicone ear tips (S / M / L)
3x pairs of foam ear tips (S / M / L)
ColorGold
Impedance (Ω)19
Efficiency / Sensitivity (dB)107
Lowest frequency (Hz)20
Highest frequency (Hz)30000
LETSHUOER EJ07M headphones  are designed for professional use. It is particularly suitable for stage performances and studio mixing by...
